Author Topic: What is this device in a little 1970's bench power supply?  (Read 979 times)
Offline jakeisprobablyTopic starter
    • Upcycle Electronics
« on: June 08, 2019, 07:44:14 pm »
I took apart a little 12v power supply I picked up from a local thrift store. Inside it's very simple but I've never seen a device before like this little bulb in the pictures. It looks like a bimetallic strip based current limiter. It was in series with the output positive voltage terminal. What are these devices called, and why are they not used (much/if at all) today?
Offline ciccio
  • Designing analog audio since 1977
    • Oberon Electrophysics
Re: What is this device in a little 1970's bench power supply?
« Reply #1 on: June 08, 2019, 07:47:51 pm »
You are correct: it's a self resetting fuse.
Last time I've seen one I was much younger..
It is very similar to the bimetallic  fuses that are placed inside motor's windings.
An example: http://www.miottisrl.com/en/prodotto/sw1/
They are current and temperature sensitive (for motor or transformer protection).
The glass body make it less temperature sensitive, so it is in effect a simple current limiter.
Best regards
« Last Edit: June 08, 2019, 08:01:56 pm by ciccio »
Strenua Nos Exercet Inertia
I'm old enough, I don't repeat mistakes.
I always invent new ones
Offline Towger
  • Country: ie
« Reply #2 on: June 08, 2019, 07:57:47 pm »
I have also seen them used as a flasher, in ET (phone home) toys!
Online floobydust
« Reply #3 on: June 09, 2019, 01:38:42 am »
It's a self-resetting thermal circuit breaker.
They are kind of neat, they trip at say 5A and take almost a minute to reset (cool off).
Offline strawberry
  • Country: lv
« Reply #4 on: June 09, 2019, 06:02:16 am »
old scool cristmass lights
contacts in vacuum can hold more current
