Author Topic: What is this IC / component?  (Read 235 times)
Offline brandon.arnoldTopic starter
    • Brandon Arnold
« on: November 16, 2024, 10:53:32 pm »
May I ask if anyone can take a look at the image and help me understand what this component does?
I have circled 4 of them, there, labeled "103" on the IC, with mask label prefix "RB...". There are 9 contacts, which are 8 pins + a large contact that has continuity with +5V (VCC). Each of the 8 pins are connected to different TTL digital bus data wire.
Maybe they are pull-up resistors. Or something to do with static / safety protection, using 8 capacitors, for example.
Thank you!
« Last Edit: November 16, 2024, 10:58:08 pm by brandon.arnold »
Offline u666sa
  • Country: ru
Re: What is this IC / component?
« Reply #1 on: November 16, 2024, 11:00:09 pm »
Resistor network. Yes, pull up resistors, only inside one package, instead of individual resistors.
The following users thanked this post: brandon.arnold
    • Brandon Arnold
« Reply #2 on: November 16, 2024, 11:03:33 pm »
Thank you so much, u666sa.
