Author Topic: What is this item found on a PCB?  (Read 4477 times)
Offline upl8Topic starter
« on: April 14, 2019, 07:36:09 am »
Found this attached to the PCB of a Tivo. It has small holes in the middle of the case and loose balls inside. It was face-down with only the white paper backing showing from above. The only identifier on it is W09.
Offline Psi
Re: What is this item found on a PCB?
« Reply #1 on: April 14, 2019, 08:04:38 am »
My guess is moisture absorber/ desiccate.
Online rstofer
« Reply #2 on: April 14, 2019, 08:21:13 am »
Maybe it provides weight.
Online ataradov
    • Personal site
« Reply #3 on: April 14, 2019, 08:23:11 am »
Weight was my first guess, but TiVO is a set top box like thing. I doubt it needs any additional weight.
But if this was on the remote, for example, then it is probably a dummy weight to make it feel more balanced.
« Last Edit: April 14, 2019, 08:37:19 am by ataradov »
Alex
« Reply #4 on: April 14, 2019, 08:35:30 am »
It only weighs 1.5 grams. As ataradov said, the Tivo is like a set top box. It has a 3.5" hard disk in it, so no need for an extra 1.5 grams. The balls inside aren't attracted to a magnet, but they easily pick up a static charge.
Offline sleemanj
  • Professional tightwad.
« Reply #5 on: April 14, 2019, 10:25:35 am »
My guess is a spill detector, maybe changes colour or something when the balls get wet.
Offline Psi
« Reply #6 on: April 14, 2019, 10:27:35 am »
can we see more photos front different angles and also see a shot of it on the pcb?
« Reply #7 on: April 14, 2019, 11:24:02 am »
I poured some water over it. The face that was visible when it was attached shows some black now, but I'm not sure it's permanent.
Some more photos attached. Unfortunately the PCB is gone. My Dad pulled it apart and asked me if I knew what it was. The "Top" photo is what you would see when looking at the PCB. The holes were facing down towards the PCB. The "Size" photo shows the residue from the glue that was holding it to the board. The five small holes are in the circle in the middle.
Offline Psi
« Reply #8 on: April 14, 2019, 12:09:14 pm »
It also reminds me of insect bait/poison.
« Reply #9 on: April 15, 2019, 10:56:57 am »
The top turned white again after it dried, so not a spill detector.
Online iMo
  • Country: va
« Reply #10 on: April 15, 2019, 11:34:40 am »
Looks like activated charcoal (carbon) in form of balls.
Absorbs smell of B and C movies :)
Offline CJay
« Reply #11 on: April 15, 2019, 12:30:26 pm »
Ah, all these educated people and none have realised it's an implementation of the CD-ROM CAV disc balancing system referenced in the patent link below for PCB balancing to ensure level flight and accurate aim in repair shops in the even of the board being designated Failed Under Continuous Test
https://patents.google.com/patent/US6061325A/en
The following users thanked this post: Gyro
Online mikeselectricstuff
    • Mike's Electric Stuff
« Reply #12 on: April 15, 2019, 12:38:30 pm »
Seems to have some PCB-trace like patterns on the surface - were there PCB tracks under it?
If so it could maybe some kind of humidity or maybe motion /shock sensor. Are the balls conductive?
Day Job: Mostly LEDs
Offline Bud
« Reply #13 on: April 15, 2019, 01:26:56 pm »
Why would a goddamn tv streaming box would need a humidity or motion sensor.
« Reply #14 on: April 15, 2019, 01:39:49 pm »
Hard disk warranty claims
Offline Psi
« Reply #15 on: April 15, 2019, 01:44:58 pm »
It couples to 3 capacitive touch pads on the pcb and provides a random number seed.
Effected by the position/stackup of those black spheres as well as humidity.
« Last Edit: April 15, 2019, 01:46:42 pm by Psi »
« Reply #16 on: April 15, 2019, 02:08:17 pm »
Why would they not use timing of user remote buttons and/or network activity for random seeding ?
Offline Psi
« Reply #17 on: April 15, 2019, 11:07:36 pm »
dunno, i'm just trying to think up as many ideas as i can.
Offline Brumby
« Reply #18 on: April 15, 2019, 11:13:45 pm »
... or spilled beer detector?
Offline Psi
« Reply #19 on: April 16, 2019, 12:05:11 am »
It looks the same as this thing from inside a HDD, just a different plastic package
https://youtu.be/5pP2tcsCnrk?t=85
I stand by my first guess
« Last Edit: April 16, 2019, 11:42:45 am by Psi »
The following users thanked this post: helius
Offline xavier60
« Reply #20 on: April 16, 2019, 02:37:36 am »
spherical activated carbon beads from this manufacturer can be 0.7mm average diameter, http://www.kureha.com/pdfs/Kureha-BAC-Bead-Activated-Carbon.pdf
HP 54645A dso, Fluke 87V dmm,  Agilent U8002A psu,  FY6600 function gen,  Brymen BM857S, HAKKO FM-204, New! HAKKO FX-971.
Offline windsmurf
« Reply #21 on: April 16, 2019, 03:34:10 am »
So that must have come out of the hard drive in the Tivo?
« Reply #22 on: April 16, 2019, 10:10:42 am »
He doesn't remember seeing any tracks under it. I don't think the balls are conductive, they stick to the side of the case if you shake it (static).
It looks the same as thing thing from inside a HDD, just a different plastic package
Yes, I think your are right. Even the texture of the balls looks the same under magnification.
Size looks about right.
I asked him today. Not from inside the drive, but it was attached to the PCB on the drive. I didn't know this until today.
So it looks like this might be a desiccant and/or filter attached by the HDD manufacturer. Found an image that looks very similar.
Thanks all for your suggestions, I think the mystery is solved.
« Reply #23 on: April 16, 2019, 11:25:15 am »
they would stick regardless of conductivity
« Reply #24 on: April 16, 2019, 03:27:05 pm »
Is that because the balls are contained in an insulating case?
