Author Topic: What is this schematic symbol? Arrow with a circle around it  (Read 812 times)
Offline cdevidalTopic starter
« on: March 12, 2024, 02:16:10 am »
It's found on page 1 of the datasheet for the LM386 audio amplifier schematic. I doubt it's a current source, which I've only ever seen depicted as a disconnected arrow inside a circle. But I'm open to correction on that.
« Last Edit: March 12, 2024, 02:24:06 am by cdevidal »
Online SiliconWizard
Re: What is this schematic symbol? Arrow with a circle around it
« Reply #1 on: March 12, 2024, 02:18:35 am »
It's a current source.
The following users thanked this post: cdevidal
Offline golden_labels
« Reply #2 on: March 12, 2024, 03:56:11 am »
As SiliconWizard said, but don’t treat it as a specific discrete component. For integrated circuits schematics depict behavior, not the actual implementation. In practice it’s likely an output of a current mirror.
People imagine AI as T1000. What we got so far is glorified T9.
Offline sparkydog
« Reply #3 on: March 12, 2024, 04:56:31 pm »
...or an LED driver. Or it could be a discrete component, e.g. an Onesmi NSI series CCR. Not saying it's likely, but it's possible...
« Reply #4 on: March 13, 2024, 02:32:22 am »
LM386 is a 8-pin PDIP/SOIC package. I’m pretty certain it doesn’t contain a discrete component. In particular not a DPAK package, which is physically larger.
Offline tooki
« Reply #5 on: March 15, 2024, 01:02:20 pm »
Yeah, no. Zero percent chance it’s a discrete component here.
Offline T3sl4co1l
    • Seven Transistor Labs
« Reply #6 on: March 15, 2024, 02:20:18 pm »
LM386 is one of those parts old enough to 1. have a fairly representative schematic in the datasheet already, but even more so, 2. have been decapped and reverse-engineered; you can inspect the physical transistors on die at your leisure.  ^-^
I don't remember it exactly, but a typical implementation in those days, was lateral PNP current mirrors.  The "lateral" detail is important because it's a cheap way to make poor quality PNPs -- hFE is quite low, which has consequences for how the mirror is designed.  For sourcing bias current into other (mostly NPN based) circuits, they're perfectly suited.
Related: http://www.righto.com/2020/06/reverse-engineering-and-comparing-two.html
I don't actually find a die photo offhand, but this isn't too surprising as the subject is very poorly represented by Google Search.
« Last Edit: March 15, 2024, 02:28:44 pm by T3sl4co1l »
Seven Transistor Labs, LLC
