Author Topic: What is this?  (Read 4425 times)
Offline timelessbeingTopic starter
What is this?
« on: November 27, 2011, 07:35:14 am »
I found it amongst some bits'n pieces I had.
Offline McMonster
    • McMonster's blog
Re: What is this?
« Reply #1 on: November 27, 2011, 07:49:13 am »
Possibly some kind of light or color sensor.
Offline 8086
    • Circuitology - Electronics Assembly
Re: What is this?
« Reply #2 on: November 27, 2011, 02:54:28 pm »
I would agree with above. Possibly light-to-frequency or something seeing as it has some kind of silicon as well as the sensor.
What I am more interested in though, is what camera you used to get up close so well to take the picture?
Offline ndictu
  • Country: sk
Re: What is this?
« Reply #3 on: November 27, 2011, 03:30:59 pm »
From the Exif data:
Orientation of image:  1
File change date and time:  2011:11:09 17:44:44
Image input equipment manufacturer:  Canon
Image input equipment model:  Canon PowerShot SD880 IS
Exposure time:  0.125
F number:  2.8
ISO speed rating:  200
Shutter speed:  3
Aperture:  2.96875
Exposure bias:  0
Maximum lens aperture:  2.96875
Metering mode:  5
Flash:  16
Lens focal length:  5
Focal plane X resolution:  15136.9
Focal plane Y resolution:  15116
Focal plane resolution unit:  2
Sensing method:  2
Custom rendered:  0
Exposure mode:  0
White balance:  0
Digital zoom ratio:  1
Scene capture type:  0
Re: What is this?
« Reply #4 on: November 28, 2011, 10:26:24 am »
It's an ordinary point&shoot camera in macro mode. It took some time to set up the shot and adequate lighting without too much reflection.  I think the most important trick was to set the camera down and use a timed shutter to achieve a still shot. But I don't think it turned out THAT great.  It's rather grainy, the highlights are blown out and the depth of field is very shallow (leads are out focus).
Offline metalphreak
  • http://d.av.id.au
    • D.av.id.AU
Re: What is this?
« Reply #5 on: November 28, 2011, 12:33:28 pm »
I've seen some tiny solar cells that look similar to that. I doubt thats what it is though.
Offline sonicj
  • updata successed!
Re: What is this?
« Reply #6 on: November 28, 2011, 11:15:03 pm »
i have this same camera and imo, it takes OK macro shots. like timelessbeing mentioned, it takes a bit of setup and a timed shutter release or remote to acquire good results.
that is a cool looking package, whatever it is!
-sj
Offline Psi
Re: What is this?
« Reply #7 on: November 29, 2011, 12:46:36 am »
Here's the best macro shot i can get...with my PHONE!  :P   (Nokia N900)
The chip in the background is a sensor from an airport Xray machine, basically an array of photodiodes.
It's supposed to have a white phosphorescent block on top to convert xrays into light but i remove it.
« Last Edit: November 29, 2011, 12:54:04 am by Psi »
