Author Topic: What does this mean on a UNI-T multimeter and can it be repaired?  (Read 612 times)
Offline epigramxTopic starter
it keeps showing that 'minus' on the top left and an "H" (only the 'dot' changes if the dial-setting is changed).
The fuse works and it was replaced to make sure anyway and it's the same on another multimeter-battery.
It broke when I went from "20" voltage setting towards OFF  while it was measuring a car battery while the alternator(car engine) was on and I wonder if it's an easy fix or a whole main chip died that costs more than the multimeter or something (it's my cheap multimeter so I have another to do tests).
« Last Edit: August 25, 2023, 12:56:49 pm by epigramx »
Offline wasedadoc
Re: What does this mean on a UNI-T multimeter and can it be repaired?
« Reply #1 on: August 25, 2023, 01:01:37 pm »
Any change if you release the HOLD function? Toggle the yellow button.
Offline BILLPOD
« Reply #2 on: August 25, 2023, 01:03:38 pm »
Good Morning epigramx, my guess is that someone pushed the yellow
'Hold' button in the center of the range switch :popcorn:
