I think the OP was trying to say that if POWER kills you or P=VI... Then 1,000,000 V x 1 mA would be equivalent to 100 V x 10 A. Both situations the power is the same = 1000 Watts. Then you could say "1000 Watts can kill you". There is a big problem with this argument. It is not even POWER that kills you... it is POWER x TIME or ENERGY that kills you.
Obviously the 2 situations are not the same as it depends on the resistance since V is related to I by R. You can't just arbitrarily assign the voltage and amperage and say "here hook yourself up to this" and expect V and I to be arbitrary values without knowing the resistance.
The VI relationship given by Ohm's law is V=IR, or V/I = R.
So in the first situation, 1,000,000 V/1mA = 1,000,000,000 ohms resistance would be needed.
In the second situation, 100 V/10 A = 10 ohms resistance would be needed.
Although the "Power" calculation is the same if you put 1,000,000 volts across a 1,000,000,000 ohm, or you put 100 volts across 10 ohm resistance... P=1000 W.... You can't ask if "power" kills you because your body resistance (or the lack of it) in the presence of a high electromotive force or potential (volts) and an unlimited source of electrons (current) is what will kill you.
For example, high voltage alone is not enough. Although the more volts obviously the more amps given a FIXED resistance (according to V=IR). When you get a static shock you could have thousands of volts but because there is a very small source of electrons available it is extremely short in duration. If you had a large reservoir of electrons continuing to flow for a long period of time then yes you would get a considerable amount of energy deposited in your body which would likely burn and boil you.
Similarly, try shorting the ends of a car battery. Yes it is only 12 V but it can deliver a huge amount of current and keep on doing that for a considerable amount of time. The 12 V in a car battery cannot overcome the resistance in your skin, that is why you have very little current going across you. But put a low-resistance device across it (like a screw-driver handle) and watch it spark and glow and get dangerously hot!
So I would say it is neither voltage or current, but BOTH since they are proportionally related by resistance. It is RESISTANCE (lack of it) that kills you in the presence of either a large voltage or current (neither one is independent of the other) and TIME (since power x time = energy which is what is needed to kill you).
