I am completely aware of the dangers lithium batteries can cause and also that it is much better choice to just use a better charger. They are not even that expensive. I just became interested in Chinese chargers and this sort of became a little project of mine, or investigation at least. I would never charge batteries unattended with these cheap chargers (Actually not with any other charger either.) and I am always charging them in a small room basically made out of concrete and have fire equipment nearby. You guys don't have to worry about my safety, although it is really nice you are thinking safety first.
The meter I use mainly is a UNI-T 139C and it has been measuring quite accurately when comparing to the bench meter at my school, so I wouldn't consider the way of measurement a problem here. I have some other cheaper meters also around the house and two of them showed exactly the same voltage. I measured the whole battery pack voltage and divided it by the amount of cells and also confirmed the measurement by measuring the individual cell voltages through the balance lead. They add up correctly and result in all of the cells being 4,28 - 4,3 volts.
I also know this is not worth it, it is a 15€ charger, so of course it is not. This is solely a project and training for me to understand if there are any ways to simply affect the cell voltage the charger is seeing and I am sure there might even sometimes be faults that lead to this.
The Schottky diode approach sounds quite interesting and I am definitely going to try that as soon as I get myself some of those.
I also found from the charger settings that it is able to charge either Lipos, Li-ions and LiFePO4 batteries and by those it means that the nominal voltage is either 3,7V (Lipo), 3,6V (Li-Ion) or 3,3V (LiFe) per cell. Do these batteries have otherwise exactly the same charging characteristics except the cell voltage? I could just for example drop it to LiFe charge and see how much under it actually charges the lithium ion cells (which I only need to charge) if the cells are charged
exactly the same way but with a lower voltage. If the charge curves are not exactly the same, then I am not going to use that method because the goal is also to have it charge Li-Ions exactly correctly. At least in theory, keeping in mind that it is a 15€ Chinese charger.
I would always rather undercharge my batteries to maybe 4,1 volts and I definitely wouldn't mind that. It is always better for the cells.
- Beni
