This might be an international thing, but your lighting circuits are 10-16A?
In the UK, lighting circuits are fused at 5A (old) or 6A breaker, for a whole floor, sometimes a whole house, wired in 1 or 1.5mm2. I know the US is different, but I thought we were closer harmonised than that. The wire in most light fittings isn't good for 16A.
I have 3 20A breakers for the kitchen and 5 16A breakers for the rest. There is no difference between lighting and outlets, in fact lights and outlets are on the same breaker (usually lights from one room with outlets from another). And this is a fairly old house, I think it was built in the 70s or so.
You would be really hard pressed to find a house that uses less than a 10A fuse/breaker per circuit. It also isn't common to separate "lighting" and "outlets" to different circuits. It is usually mixed, so that if one breaker pops, you don't end up in complete darkness or only with lights and no outlets.
In France it was similar, also in Denmark and Slovakia. Even though you could find some weird shit in some very old or very "DIY" installations.
In the UK you have this strange ring-style wiring and fuses in the plugs, that doesn't exist anywhere on the continent.
