There as many vocal people that disagree, and "push" modern digitising scopes.
Alas, I'm one of them. Although I have that Tek 485 and built my first analog scope from plans in the ARRL Handbook clear back in the late '50s, I view analog scopes vs digital scopes the same way I view the slide rule versus the HP48GX. I got through undergrad with a slide rule, I still drag it out from time to time, but I actually use a calculator.
I don't agree that there is anything special to learn from an analog scope. The primary controls (V/div, t/div, position, trigger type/level) are the same on any scope. But the digital scope brings so much more to the game and, in particular, Single shot capture. In either case, the learning curve is going to be about the same but there is so much more capability with the modern DSO.
A used, but working, analog scope may fill a financial check box but that would be one of only two reasons for buying such a thing. The other being bandwidth. It's pretty easy to find a Tek 485 350 MHz scope for a couple of hundred bucks, plus a bunch for shipping. In the end, it's a great analog scope with a bunch of bandwidth, plenty of features and not a bit of measurement capability.
I'm not sure what the resale would be on a used (again) analog scope but I'll bet the digital will hold its value pretty well.
Today, on eBay, there are a couple of 485s One is about $200 plus $24 shipping and the other is refurbished, warranted and calibrated for about $500 and $50 shipping. At the same time, on Amazon, the Rigol DS1054Z is $349 with free shipping. Kind of in the middle of the cost range between a dubious 485 and a known working/calibrated 485.
If the money isn't there for the Rigol, so be it. But under no condition is the used analog going to compare with a modern DSO - particularly a 4 channel DSO. And the resale on the Rigol is going to be around $315 according to eBay. Not a bad deal if things don't work out in electronics.
And the new DSO works, has a warranty and probably doesn't need a lot of capacitor replacements. And if you need one of the unobtanium custom ICs, you are just out of luck.
I simply don't see the justification for a used analog scope. I have one, it works very well, I'm not going to junk it but I actually use the DSO.
