Author Topic: Suggestions required for small embedded computer  (Read 1210 times)
Offline Vindhyachal.taknikiTopic starter
« on: June 23, 2016, 04:04:40 pm »
1. I need a camera interface which some audio output. Image taken has to be processed inside & its contents to be spoken out.
Earlier I thought of using raspberry pi as it has camera & audio out, then internally OpenCV can be used.
But it has large form factor, I need something smaller. Also raspberry pi has large footprint & major problem is its current consumption also.
I need to tailor down my application for this task only.
2. Any suggestions on it which board can be used?
Offline ebclr
Re: Suggestions required for small embedded computer
« Reply #1 on: June 23, 2016, 04:19:05 pm »
Do you know pi zero ?
What about arducam ?
