Author Topic: What rating is this resisitor?  (Read 346 times)
Offline Robbie010
« on: February 04, 2019, 11:49:31 pm »
As title, can ayone confirm what the rating of this resistor is please?
Offline Benta
Re: What rating is this resisitor?
« Reply #1 on: February 05, 2019, 12:03:50 am »
0.3 W.
Offline Robbie010
« Reply #2 on: February 05, 2019, 12:22:14 am »
0.3 W.
Sorry, I'm not sure what that means!?
I am looking for the Ohms and tolerance rating but I'm struggling to read the colour bands. Is it:
Brown-Black-Black-White-Blue = 100G ohm .25%
Brown-Black-Black-Gray-Blue = 10G ohm .25%
Brown-Black-Black-Silver-Blue = 1ohm .25%
Or is it the opposite of those?
Blue-White-Black-Black-Brown = 690 0hm 1%
Blue-Gray-Black-Black-Brown = 680 ohm 1%
Thanks.
Offline basinstreetdesign
« Reply #3 on: February 05, 2019, 12:37:02 am »
Thanks.
Checking this site: http://www.keith-snook.info/component-colour-codes.html I believe this one is correct - 680 Ohms, 1% and 1/4 Watt.
STAND BACK!  I'm going to try SCIENCE!
Offline Hiemal
« Reply #4 on: February 05, 2019, 01:38:20 am »
0.3 W.
Thanks.
Just to clarify so you know in the future:
Generally when someone says "rating" of something that implies the power dissipation it can handle, hence Benta's response.
The VALUE of the resistor is what you were searching for. And if in doubt, you could always desolder it and try to read it with a multimeter too, or read it in circuit potentially, depending on what kind it is.
Offline Ian.M
« Reply #5 on: February 05, 2019, 03:11:32 am »
It cant be any of the Gigaohm possibilities you offered as if it was, it would have to be mounted in free air between teflon standoffs as the bulk resistivity and surface resistance of FR4 PCB can be as low as 100 Meg m and 100 Meg/sq respectively.   There's no point in soldering a resistor to two pads maybe 5mm apart if the resistor is a better insulator than the PCB between them!  :-DD
One doesn't normally see resistors that are closer tolerance than 1% in simple transistor circuits.   1% resistors are absolutely ubiquitous and fill the market niche that in the old days was filled by the E12 10% resistor.   Therefore, even if you are half blind and cant distinguish between white, grey and silver, and the camera colour rendering is also crappy enough to confuse us, 1 ohm 0.25% is very unlikely.
The choice between 680 ohms and 690 ohms is more difficult. Neither are E96 series (1%) preferred values.  690 is an E192 series (0.5%) value but one would expect a closer tolerance than 1%, and 680 is an preferred value in the E6, E12, and E24  series.   There's a lot of design inertia in the trade, and experienced engineers still tend to use E12 series value whenever practical if the tolerance is non-critical so a number of resistor manufacturers offer E12 series values in their 1% resistor range so their products don't inadvertently get excluded from the BOM by less technically oriented purchasing departments who aren't authorised to adjust the value to the nearest one in a closer tolerance  series.
Therefore I agree with basinstreetdesign, 680 ohm 1% is the most likely.
Its power rating is more difficult as better materials tecnology has enabled many resistor  manufacturers to increase the max power rating available in traditional 1/4W and 1/2W body sizes.   It *looks* like a 1/4W part but that's no guarentee nowadays.  It certainly wont be 1/8W or 1/2W.  If it *is* a 1/4W part, it should have less than 13V across it.  As there's no sign of PCB discolouration, its unlikely to be running at max dissipation, so it probably has 10V or less across it.   Is that consistent with its position in the circuit and the applied voltages?
