Author Topic: Basic switch question  (Read 1318 times)
Offline jy0un9Topic starter
« on: November 15, 2014, 11:16:11 pm »
Hi
First post very simple question
I'm trying to change the switch on an old Weller soldering station to a  illuminated switch i have
The old switch has 4 pins (two wires from the plug and two from the transformer) the new switch has 3 pins
Can i use this switch if so what wires do i connect to what pins
Attached two low quality images
Thank you
Offline German_EE
Re: Basic switch question
« Reply #1 on: November 15, 2014, 11:27:15 pm »
DO NOT USE THIS SWITCH
The old switch was designed to switch mains voltages between the plug and the transformer primary, your replacement switch is designed to handle 12 volts and (almost certainly) contains a 12v bulb inside to indicate when the contacts are closed.
Please go back to your local retailer and ask for a Double Pole MAINS RATED switch.
« Last Edit: November 15, 2014, 11:29:47 pm by German_EE »
Warren Buffett
« Reply #2 on: November 15, 2014, 11:30:16 pm »
Thanks alot
