Author Topic: What shall i replace this Capacitor with ?  (Read 571 times)
Offline Retromat
  • Too old to be a millenial
    • Retr-o-Mat Youtube
« on: November 20, 2020, 01:55:13 pm »
Greetings!
today i wanted to get a old [attach=1]ISA Graphicscard to work and noticed a broken off, in my opinion, tantal capacitor.
The values say its a 10uf Capacitor. Is that correct? I do not own those types of capacitors but i have some ceramic capacitors laying around and wonder if i could replace it with them.
also, does 10uF doesnt sound a lil too high for this lil fella?
Offline pigrew
Re: What shall i replace this Capacitor with ?
« Reply #1 on: November 20, 2020, 02:04:04 pm »
It's a 10uF 16V tantalum capacitor. Without a circuit schematic, it's unclear if a ceramic capacitor would be an acceptable substitute.
Be careful with orientation, they'll catch fire if you reverse the polarity.
Offline Infrared_Fred
« Reply #2 on: November 20, 2020, 03:16:33 pm »
That capacitor looks to be the correct size for its value and voltage range, i.e. I don't think it is broken off.  A capacitor like this https://www.digikey.com/en/products/detail/avx-corporation/TAP106K016CRW/3661004 matches the apparent size of your capacitor.
Offline Retromat
« Reply #3 on: November 20, 2020, 03:19:14 pm »
thanks!
yes i took a picture of a unbroken one for easier reference. Hmmm os i better get a new tantal one the nand do not replace it with anything else.
Offline David Hess
  • DavidH
« Reply #4 on: November 20, 2020, 06:38:31 pm »
You could replace it with a 47 to 100 microfarad aluminum electrolytic.
Offline uli12us
« Reply #5 on: November 21, 2020, 10:19:47 am »
No, replacing with a standard Electrolytic is nearly always ok, but the capacity must be the same, the voltage can be higher.
Offline David Hess
  • DavidH
« Reply #6 on: November 21, 2020, 11:17:05 pm »
That depends on the application.  If decoupling applications it is the ESR and impedance which matter and not the capacitance, in which case it takes an aluminum electrolytic of 4 to 10 times the capacitance to yield the same performance.
Offline james_s
« Reply #7 on: November 22, 2020, 04:32:28 am »
I've measured the ESR of a few different tantalum capacitors and while it was lower than a typical cheap electrolytic it was not THAT low. I would be quite surprised if a reasonable quality aluminum electrolytic of the same value didn't work.
Offline tggzzz
« Reply #8 on: November 22, 2020, 10:06:29 am »
In some circuits a capacitor with a lower ESR can cause problems. I guess that isn't the case in your circuit.
If using a tanatalum, ensure the rated voltage is at least twice the voltage in the circuit. A 16V tant would be fine for 5V, but 12V would be questionable.
With MLCC capacitors, the capacitance is strongly dependent on the applied voltage. It is normal to "lose"  80%-90% of the capacitance when running them at their rated voltage.
David Hess' suggestion is sensible for a standard alumimium electrolytic. Some of the new modern polymer electrolytics have a surprisingly low ESR.
Offline mariush
« Reply #9 on: November 22, 2020, 12:24:26 pm »
I'd use a 10uF 35-50v rated electrolytic capacitor.
A 10uF 16-25v electrolytic would probably have a bit too high esr compared to that of the tantalum capacitor (which i assume it would be somewhere around 0.15-0.3 ohm esr)
Offline james_s
« Reply #10 on: November 22, 2020, 05:28:56 pm »
My experience has been that electrolytics with a higher voltage rating have higher ESR, all else being equal. Those with the smallest physical size also typically have higher ESR.
Offline David Hess
  • DavidH
« Reply #11 on: November 22, 2020, 05:32:40 pm »
The high frequency performance of solid tantalum capacitors is better than that of aluminum electrolytics which a common ESR test will not reveal, so it takes a larger value of capacitance to get a similar impedance at higher frequencies.  This is reflected in application notes for regulators where the suggested output capacitor will be either like a 1 microfarad tantalum or a 10 microfarad aluminum electrolytic:
https://www.ti.com/lit/ds/snvs778e/snvs778e.pdf?ts=1606066065524&ref_url=https%253A%252F%252Fwww.google.com%252F
https://www.ti.com/lit/ds/snosbq7c/snosbq7c.pdf?ts=1605982101539&ref_url=https%253A%252F%252Fwww.google.com%252F
