Author Topic: What stops the power 'jumping' between the pins of jst connectors and shorting?  (Read 1102 times)
Offline electroniclearner820327Topic starter
I have bought a few of these: https://www.switchelectronics.co.uk/products/2-way-male-prewired-jst-smp-connector-15cm?_pos=10&_sid=aecc4e2c7&_ss=r
https://www.switchelectronics.co.uk/products/2-way-female-prewired-jst-smp-connector-15cm?_pos=16&_sid=aecc4e2c7&_ss=r
I got them with the idea that rather than having to make a new fuse block wire run every time for circuits of similar current I could just swap the connector for different devices.
I got to wondering though, since when I get + and - wires to touch accidentally this often blows a fuse. When the male is not connected, these exposed pins are rather close together so what stops the current from 'jumping' and doing the same thing?
Offline wasedadoc
Until the voltage difference is high enough (volts/metre) to ionise it, air is an insulator.
The following users thanked this post: electroniclearner820327
Offline Psi
Yep,  or if the pressure gets super low and you have some unusual gas mixes around, then things can get really crazy.
Distances that you'd never think would arc over in a millions years suddenly do at very low voltages.
Things like 900V jumping a meter.
The following users thanked this post: RJSV, electroniclearner820327
Online brucehoult
Because you need about 3000 V to ionise a 1mm gap between parallel plates or wires, making a spark.
However it might be as low as 1000 V per mm for pointy tips, so better to keep below that anyway.
The connector you point to has a lot more gap than that, and will be used with a lot less voltage.
Offline HwAoRrDk
If you look at the datasheet you'll see that the JST SM series is rated for up to 250V. This is the operating voltage, the level at which it is guaranteed to perform as advertised. So you can see that even a fairly small connector like this can be used at quite high voltages. Note though that there is another voltage rating, the withstanding voltage, which is 1500V AC. This is the level at which the insulation (i.e. the plastic) between pins may break down and allow current to pass - even a very tiny amount. So bear in mind it's not just about the air between the pins, but also the plastic.
(BTW, why in the datasheet is the withstand voltage labelled just as "1500V AC/minute". I thought that V/minute was to do with ramp testing, but specifying the ramp rate without a maximum doesn't make sense to me. I'm sure they mean a maximum of 1500V, so are they also implying "ramp to 1500V over a period of 1 minute"?)
Offline SteveThackery
I'm guessing it means it'll withstand 1500V for one minute.
Offline coppice
It might be less than 1000V/mm on a humid day. 3000V/mm is for dry air. If there is any absorbent contamination on the surface of the plastic a humid day might see significant leakage even for low voltages. You can't just quote people best case conditions.
Offline coppice
There are lots of test specs that equipment have to pass which have that 1500V requirement. Its actually 1500V sustained for one minute. You'll find it in lots of land line telecoms specifications, for example.
Offline HwAoRrDk
I see. So why write it as 1500V per minute? To me that implies a rate of change. :-//
Offline coppice
Its a shorthand you'll see on many things. If you see 1500V/min where it can be interpreted as "passes the 1500V for one minute insulation breakdown test" it probably should.
Offline RJSV
   The volts per meter figure is for CLEAN areas near the pins,  so that's a factor that needs to be happening,  ongoing.
   Long power cords introduce some degree of inductive kick-back,  especially with big loads and motors.
00
   Manufactures sure do push limits on things like connector size,  which is unfortunate but consumer pressure can be daunting, (to go smaller).
Online brucehoult
Sure, you should leave a margin. I'm just pointing out that you should leave a margin from 1000V/mm, not from 3000V/mm.
250V with a few mm gap between is not going to be a problem in any situation bar contamination causing a short by something other than air.
Ok well I only plan to use on 12v system so should be no issues in my case.  ;D
Offline PGPG
Minute for electronic is eternity.
If it were 1500V/us you could expect it is rate of change specification but not when the time is minute.
Some tests are specified to make test for eternity (=1 minute :) ) and you should it read as device passes that test.
Online brucehoult
With 12V on something designed for 240V you are more likely to run into current limitations!
Offline CaptDon
  • Country: is
What stops it is the same thing that stops the electrons in the 240v wall socket from frying you as you sit in your recliner 2 metres from the socket. Air makes a real good insulator 99.9% of the time.
Offline golden_labels
As a supplementary read, if you want to learn more on the topic, the three keywords you need to search for:
  • Clearance
  • Creepage (or creepage distance)
  • DIelectric strength
A table of dielectric strengths on Wikipedia gives a rought feel of what values we’re talking about. Note that locally field strength depends on conductor shape. As somebody mentioned earlier, electric field will have very high value around sharp edges/points, easily exceeding the limit. We need to take that into account and not blindly assume that 5 mm gap can unconditionally withstand 15 kV in air. Otherwise you could just put on a pair of work gloves and hang from the nearby high tension line (which I strongly suggest not to do).
To all what has been written above, there is a small asterisk. It holds very well for the original scenario of the connector, a spark, and a fuse blowing. No worries about that! But it only remains true around the DC regime. I don’t know, how much did you learn so far. But don’t get too much attached to the notion of insulators not conducting current. Not in unconditional, absolute sense. Dielectric strength decreases with rising frequency, and also DC resistance gets replaced with frequency-dependent impedance. The former will not be a practical problem unless you design chips or go into materials science, the latter will have no implications for electrical safety. But worth knowing this is only a simplification.
« Last Edit: February 27, 2025, 03:11:15 pm by golden_labels »
People imagine AI as T1000. What we got so far is glorified T9.
The following users thanked this post: electroniclearner820327, D.Burnette
