Ok – here we go. Flux. I know I’ve got a problem.
For some while I’ve been using Fry Fluxite, applying with a toothpick and cleaning with isoprop and a toothbrush, but it clumps into brown stuff which isn’t easy to get off the board.
You know… I’ve got a funny feeling I’ve been using the wrong stuff for electronics. Please stop chuckling.
I’m starting to try CW8100 no clean flux pen; not that cheap but so far I like it. I also watched SDG’s flux video and started wondering. I’m reading from things that “no clean” means non-acidic so doesn’t need to be, “deactivated” by heat and is safe to leave on the board.
I’m UK, so that factors into postage and prices.
The CIF No clean can be had from Farnell for about £15, but it seems that quite a bit is applied to the joint and I’m wondering how long 10cc will last at that price.
(actually, two tubes+VAT and delivery… £33.20)The Banggood can be had about £9 delivered for three tubs of 150g
(1 tub is £6.45, so three is cost effective) but it isn’t no clean. I’m wondering whether it will just do the same as the Fry when I attempt to clean it off… although I have read some discussions where people don’t bother to clean their flux off. The best I can find on the details is, “IC and PCB for no corrosive” so I’m reading that as non-acidic… because I do wonder how much damage I can do with isoprop and a toothbrush, particularly with the quantities I’ve had to apply to clean off the Fry.
Incidentally, there was another version of the ZJ-18 at 50g and a silly price, but looked to have more rosin.
Refillable flux pens are knocking up towards 3 digits in the UK for anything decent… there are e-bay versions but I do wonder. In among my concerns for that is how long the tips last… and that’s before getting into the discussion of liquid types and mix ratios.
It seems that getting good results for hobbyists who are a little tight on the purse strings, is an ongoing battle. Grateful for anything that people can add to my thoughts please, because so far it seems like the flux is ramping up to potentially be the most expensive part of this hobby.
