The color and the FP marking would make you think it's a Nichicon / Fujitsu
Functional
Polymer capacitor, 390uF 2.5v ... example of datasheet:
ftp://helpedia.com/pub/temp/datasheets/capacitors/Nichicon/Polymer/2009fpcap_catalog_s8.pdfThe ESR of these capacitors is super low, 0.01 ohm or less.
The problem I have is that those capacitors have FP on them only if they're through hole, if they're surface mounted they actually have the series code on them ... cs, ck, cg etc
It's not unheard of to have some custom batch of capacitors made, especially if it's a Toshiba, but it could also very well be some polymer / functional polymer made by another company. Though who use that intense red color... i don't know.
But basically, the ESR70 and these cheap esr meters are not accurate enough to determine the ESR of polymer capacitors, these have esr under 10mOhm and the esr meter has 0.01 ohm as the lowest value it reports.
