Author Topic: What through hole device can I use instead of a SOT23 format BF862 please?  (Read 1097 times)
Offline Chris WilsonTopic starter
  • Race car engineer, dog lover, hoarder.
https://www.nxp.com/docs/en/data-sheet/BF862.pdf  shows the specs.
The circuit it would be used in is hopefully attached. Thank you!
Best regards,
                 Chris Wilson.
Offline ogden
  • Country: lv
Re: What through hole device can I use instead of a SOT23 format BF862 please?
« Reply #1 on: December 02, 2018, 02:13:46 pm »
It's just LED current limiter. You can use resistor.
Offline T3sl4co1l
    • Seven Transistor Labs
« Reply #2 on: December 02, 2018, 02:16:14 pm »
If the inputs are the voltages shown, just use 1k resistors.  They're literally using them as (8 to 20mA) current limiters.
Ew, a step-up gate drive transformer, and no winding details (core, but not winding).
Ew, ancient fatass transistors too.  Those 1 ohm gate resistors aren't going to do anything.
I've seen Tesla coil circuits better than this, which is saying something... :-\
Ed: ew, and using a 6N136 in phototransistor mode.  Just use a 4N35, except those aren't fast enough. :palm: It just gets worse the more I look at it...
Seven Transistor Labs, LLC
Offline bson
« Reply #3 on: December 02, 2018, 02:17:59 pm »
You should be able to drop in any N channel JFET with a suitable Ids at Vgs=0.  For example, J110 (10mA @ Vgs=0), J111 (20mA @ Vgs=0), both available in a  TO-92 package.  But it really depends on what LED current you want.  The quiescent current also isn't a hard specification, so we're talking ballpark.  I believe the max LED current for the 6N136 is 25mA?  The J110 probably is a good starting point.
J110, J111 in TO-92:
https://www.mouser.com/ProductDetail/InterFET/J110?qs=sGAEpiMZZMv4z0HnGdrLjo0W1AxRZQdlXPGpjxX7bVahwwoTN%2fTXPg%3d%3d
https://www.mouser.com/ProductDetail/ON-Semiconductor-Fairchild/J111?qs=sGAEpiMZZMv4z0HnGdrLjpo3FY8YkyPv%2ff16NpPbr4w%3d
Be warned, these devices are ESD sensitive.  Always make sure you're grounded when handling discrete JFETs.
« Last Edit: December 02, 2018, 02:22:05 pm by bson »
