Try an antenna tuner. They're very simple to make, but you'll need to have a good understanding of basic AC circuit principles (ie, complex impedances) to design one
A good project, but no need to worry about the complex impedences.
Take one or two variable capacitors and a coil (toilet roll, thin insulated winding, tap every 5 turns or so) and connect them in almost any way possible and you'll get some sort of impedence transformation.
Whichever connection and setting produces strongest signal strength is best.
It helps to have an in/out switch so you can tell if the tuner's doing anything or not (it won't help if your antenna's already optimum for a particular frequency but will help on others).
