Author Topic: What to do with +/-26VAC center tapped transformer ?  (Read 2047 times)
Offline lordvader88Topic starter
« on: September 05, 2018, 03:36:24 am »
I have about a 100W transformer from a stereo. Its the only center tapped trans I have, and I wanted to make some signal generator circuits, including using a XR2206 but is Vmax is +/-13Vdc , this trans. would be about +/-35Vdc rectified
Now I plan make a general linear PSU with some big transistors. But what would I even do with that much voltage? What bench stuff do people make for fun or for equipment that would need so much voltage ?
Offline bitseeker
Re: What to do with +/-26VAC center tapped transformer ?
« Reply #1 on: September 05, 2018, 04:03:00 am »
General purpose linear bench power supplies are commonly found with 30V/3A or 30V/5A output. It's not unusual for audio power amplifiers to have ±20 – 30V power rails.
It's all relative, of course. Talk to the vacuum tube folks where power rails are 300 – 400V.
« Last Edit: September 05, 2018, 04:05:12 am by bitseeker »
Offline GadgetBoy
« Reply #2 on: September 05, 2018, 04:05:09 am »
I could definitely use that transformer myself. You could use it in a full wave rectified circuit for ~18V. Put a half-wave rectifier on each outer tap of the transformer, using the centre tap as ground. You'll end up with a full wave rectified signal, which you can then filter and smooth.
Sent from my ONEPLUS A3000 using Tapatalk
« Last Edit: September 05, 2018, 05:06:56 am by GadgetBoy »
Offline Cliff Matthews
    • General Repair and Support
« Reply #3 on: September 05, 2018, 04:14:17 am »
Is that 26vct unloaded? I recall 25.2v is a common voltage, somewhere way back. Of course you could always peel a small bit of the outer insulation where the CT wire comes out, and you'll find you can divide that secondary into 2 distinct windings. I've done this many times, soldered it back up and over-sprayed the solid-core wire with auto ignition spray. YMMV
Offline HB9EVI
« Reply #4 on: September 05, 2018, 11:52:51 am »
I'd use it for an audio amp
Offline Benta
« Reply #5 on: September 05, 2018, 06:56:32 pm »
It's perfect for a 30-0-30 V, 1.5 A linear bench supply (variable, of course).
Or a 30 V, 3 A bench supply, either opening the center tap and paralleling the windings, or using two rectifiers with the center tap.
« Reply #6 on: September 05, 2018, 08:18:58 pm »
A little confused, the thread title says "+/-26VAC center tapped" but I fail to see where a XR2206 needs so much beef, when a wall wart and rail splitter would do...
Offline bitseeker
« Reply #7 on: September 05, 2018, 08:29:19 pm »
It doesn't. OP pulled the xfmr from a stereo system and wondered what to do with it since it's so beefy.
« Reply #8 on: September 05, 2018, 08:37:45 pm »
The xr2206 can only handle +/-13Vdc rail to rail. Pretty much all ICs I have like LM723, opamps, etc can't use this transformer either, without lowering the voltage 1st.
I'll look into making a linear PSU with big power transistors, I have lots of 2N3055 and heat sinks. I bet I'll need power resistors tho, and big current sense resistors.
Offline Dr.Krieger
« Reply #9 on: September 06, 2018, 09:55:10 pm »
Of course you can use a LM723 for more than 30V, you just need to use a PNP Driver to power those 2N3055. For example look at the Velleman K7200 PSU to see how this is done, i made a clone of that that would go up to 70V (not the one attached).
You just need a secondary supply voltage for the LM723 and any other OpAmps, nothing a Zener or a 7812 can't do if you don't have a dedicated Trafo or winding ;)
« Last Edit: September 06, 2018, 10:37:12 pm by Dr.Krieger »
Offline Dr.Krieger
« Reply #10 on: September 06, 2018, 10:15:12 pm »
You will only need two Diodes to make a full-wave rectification using your center-tapped "26Vac/100W" trafo, that would give you ~35Vdc so a nice 0-30V 0-3A Power supply!
Come to think of it, even a simple LM338 in TO-3 could handle that, well maybe if you removed a couple of turns for a bit lower Vin...
Oh and ofc don't try to get those 3A at a low output voltage, remember high Vout/Vin (or transistor's Vce*Ic) raise dissipation...
« Last Edit: September 06, 2018, 10:28:30 pm by Dr.Krieger »
