Author Topic: What to look when looking for a FET or MOSFET equivalent  (Read 825 times)
Offline gkmaiaTopic starter
  • Electronics Hobbyist
« on: December 11, 2019, 06:51:08 pm »
What are the key ratings to consider when replacing a FET or MOSFET for and equivalent apart from voltage and current ratings?
Offline magic
Re: What to look when looking for a FET or MOSFET equivalent
« Reply #1 on: December 11, 2019, 10:22:23 pm »
SOA, threshold voltage, RDS(on), gate charge, zillion of things...
What kind of application, what kind of FET?
« Reply #2 on: December 11, 2019, 10:32:42 pm »
I suspected you could look at a zillion things, but if you were to simplify these zillion things to a couple that are the most critical ones apart from voltage and current what would those be?
Offline Circlotron
« Reply #3 on: December 11, 2019, 10:40:04 pm »
The most critical things vary, depending on the application. If you tell us the application we can narrow things down a *lot*.
Offline aheid
  • Country: no
« Reply #4 on: December 12, 2019, 09:59:21 am »
You can simplify somewhat but it is highly dependent on application. Attributes which are important in some applications can lead to detrimental aspects for another application. For example a good switching MOSFET typically won't work well in the linear regime. IIRC high voltage tolerance leads to higher capacitance, which is very bad for other applications.
Offline GeorgeOfTheJungle
  • Country: tr
« Reply #5 on: December 12, 2019, 10:16:54 am »
The thing I always double check is Gate Threshold VGS(TH)
« Last Edit: December 12, 2019, 12:41:39 pm by GeorgeOfTheJungle »
Offline magic
« Reply #6 on: December 12, 2019, 01:24:27 pm »
Probably mostly the things I listed before.
Load switching: RDS(on) and VGS(on)
PWM: ditto plus perhaps gate charge
Linear: SOA, power dissipation vs temperature, maybe VGS(th)
