Author Topic: What to put in the place of desoldered microphone?  (Read 302 times)
Offline Bob Sava
« on: June 18, 2021, 03:26:48 pm »
After de-soldering a microphone, to keep the circuit from picking up any noise, should I solder a resistor or leave it open?
Online fcb
    • Electron Plus
Re: What to put in the place of desoldered microphone?
« Reply #1 on: June 18, 2021, 03:58:08 pm »
It depends.  If it's a condenser microphone then leaving it o/c will be fine.  You might find that some AGC in the system winds the gain up - again it depends on system.
If you're concerned about it floating about then perhaps add a 1K5 in it's place (I've seen a few of condenser mic's are powered from 3.3V via a 1K5 or so), else you could put a capacitor of perhaps 100nF (risk it acting as microphone if you're unlucky).
Prob's just try it.
**CTL502 low cost Curve Tracer now shipping**
The following users thanked this post: Bob Sava
Offline ejeffrey
« Reply #2 on: June 19, 2021, 01:34:12 am »
A resistor to ground reduces the chances for hum pickup if you care. Probably leaving it open is fine.
