I have one or two circuits that I won't want to use much. Maybe once every couple of months or less.
In these cases how can the circuit be connected and disconnected and/or plugged/unplugged when not in use?
It would be silly to have to unscrew the wires at the fuse block each time or take out the fuse each time.
Could I have it so the +/- wire from the fuse block can go a little way from the main circuit board, to give me access with my hands easily and then some king of pluggable connector so the wire can be stored away when not in use?
Are switches appropriate here? It would be ok for one connection I am thinking off, to just keep it off when not using, as otherwise there is always an LED lit up, but in another case, where the rest of the wire run would be several meters, then I would like to stow away that extra wire when not using it.
So for the latter case is there a way to make it plug and unplug like you would a usb into its socket? I am not sure what these connections would be called.
Am I just looking for general 'connectors'?
