https://youtu.be/YQ7SXJqIpzsIn the 23:10 of the youtube video above, the presenter does a p-channel mosfet test for short, using his bench power supply on the circuit.
From what i understood, he disconnected the charger and with his bench power supply he applied the nomimal 19v with 0.5A of current on the Drain of the suspected mosfet. The PSU (and not the DMM how he did that ?) showed about 0.2A and he concluded that the mosfet is not shorted. I suspect the he tried to switch ON the mosfet externally but i can not see the actual wiring.
Can someone explain how this test works ? And the other thing i saw is that this laptop motherboard had two mosfet one n-channel that outputs to a p-channel. Why this combination is used ? I mean what is the purpose of this?
PS: Is safe to touch a circuit of 19V - 2A ? In another video he used exactly that setting to his power supply to find a short - to - ground part (it was an smd capacitor) just from the heating !!
