Author Topic: Can 3.3V be obtained from 3.7V with LM1117?  (Read 813 times)
Offline merymeryTopic starter
  • Country: tr
« on: June 04, 2021, 07:29:42 am »
When I look at the LM1117 Datasheet, it says 4.75V<Vin<10V is required to get 3.3V. My circuit supply is 3.7V, is there a way to get 3.3V from 3.7V with the LM1117?
Online wraper
  • Country: lv
Re: Can 3.3V be obtained from 3.7V with LM1117?
« Reply #1 on: June 04, 2021, 07:32:44 am »
Do you really have 3.7V or it's a lithium battery?
The following users thanked this post: merymery
Offline tszaboo
« Reply #2 on: June 04, 2021, 08:15:07 am »
The typical dropout voltage is 1.1V at 100mA. Its just not a good choice for battery powered circuits.
  • Country: tr
« Reply #3 on: June 04, 2021, 08:41:50 am »
I actually have the 3.7V supply from the power supply
Online xavier60
« Reply #4 on: June 04, 2021, 11:31:46 am »
It can be done with a TL431 controlling an N-ch MOSFET. A pullup resistor is needed for the Gate to some higher voltage source like 12V.
HP 54645A dso, Fluke 87V dmm,  Agilent U8002A psu,  FY6600 function gen,  Brymen BM857S, HAKKO FM-204, New! HAKKO FX-971.
Offline tunk
  • Country: no
« Reply #5 on: June 04, 2021, 11:39:46 am »
I guess it depends on how accurate the 3.3V needs to be - maybe you could find a diode (or diodes) with a ~0.4V drop.
Online Zero999
  • 0999
« Reply #6 on: June 04, 2021, 11:41:27 am »
A zener diode will drop around 400mV, but it will depend on the temperature and low. At very low currents, it will hardly drop and voltage and a much higher currents it'll drop move than 400mV.
What's the acceptable voltage range of the device you're powering and how much current does it draw?
The TPS784 will work with 3.7V in and 3.3V out, at currents of up to 300mA.
https://www.ti.com/product/TPS784
