Author Topic: What Voltage is used to calculated capacitor charge?  (Read 560 times)
Offline implorTopic starter
« on: November 24, 2019, 02:29:27 pm »
Is there a standard that say what voltage to use when determine a capacitors capacitance?
Example:
you have a 1uF rated at 50V capacitors.
is that 1uF at 50V?
C = Q/V
Offline Kleinstein
Re: What Voltage is used to calculated capacitor charge?
« Reply #1 on: November 24, 2019, 02:36:08 pm »
In most cases capacitors are quite linear and it does not really matter which voltage to use.
The normal way is to use a small voltage (like 1V) - so the same instrument can test all most capacitors.
Especially with some MLCCs (class 2) however this can matter and the capacitance values given are for low voltage with no bias.
« Reply #2 on: November 24, 2019, 02:55:49 pm »
Sound logical ;).
the confusion is because i'm thinking of Capacitance as Energy but it's not.
I was thinking about how using a high voltage rated capacitor would impact the amount of stored energy. Example 50V MLCC vs 25V MLCC (ignoring derating)
But when I'm now doing some math I see it's only dependent on the accentual applied voltage and not the maximum rating.
W = (C*V^2)/2
Thanks for the reply  :-+
