Author Topic: What's this?  (Read 2699 times)
Offline Skippy
What's this?
« on: May 27, 2012, 10:47:25 pm »
Can anyone identify what this is? Want to buy some, but it would be easier if I knew what they were called....
It's a crimp terminal of some sort- a wire goes in and you crimp it. The other end is a kind of spring loaded fold of metal that clips into a socket and stays put, but you can apply pressure and pull it out.
Any ideas?
Offline Psi
Re: What's this?
« Reply #1 on: May 28, 2012, 12:11:39 am »
Can you post a closeup in-focus pic of both the terminal and the connector it fits into?
Offline FenderBender
    • The Solid State Workshop
« Last Edit: May 28, 2012, 12:20:10 am by FenderBender »
Offline JSnyder
Re: What's this?
« Reply #3 on: May 28, 2012, 12:39:21 am »
It looks like the wiper from a standard Molex type of connector. Very common, we need a picture of the plastic connector it came out of to find a suitable replacement
http://narkedat90.com/shop/product/molex_connectors/
Doing a search for Molex KK pin or connector should give you some close results
« Last Edit: May 28, 2012, 12:44:33 am by JSnyder »
Offline pickle9000
Re: What's this?
« Reply #4 on: May 28, 2012, 01:05:53 am »
08-50-0106 Molex
...mike
Offline Skippy
Re: What's this?
« Reply #5 on: May 28, 2012, 10:55:03 am »
Sounds pretty reasonable. It's attached to the neon indicator bulb in a kettle, and is used to attach to the base of the kettle. It hasn't come out of any kind of housing though.  I'm trying to replace the bulb (yeah, I know, really high level electronics).
The main difference between this and the Molex seems to be that it has a hole in the middle of the prong, but I guess something like this Molex could work.
