This thing runs off a 6v A.C. source to power the synchronous motor. Has about ten Leds of different colours that uplight your object for display. On the pcb are 4 diodes, 2 filter caps, 2 trannys and a few resistors AND this thing sticking up on a separate small board. I assume this is some kind of ic to make the lights do a pretty pattern, but never seen one like this. The light show on my unit is not working properly, so I suspect this component. Anyone know if I can get a replacement anywhere? Thanks
