Author Topic: What's the most dangerous failure's these days ?  (Read 4056 times)
Offline ebastler
Re: What's the most dangerous failure's these days ?
« Reply #25 on: July 28, 2019, 08:06:07 pm »
http://www.forfyre.com/the-lithium-safe-battery-bag-for-the-fire-protection-of-lithium-ion-batteries-that-catches-fire-due-to-thermal-runaway/?lang=en
That picture is rather misleading, I'm afraid. This severe FedEx accident had nothing to do with burning lithium batteries:
FedEx Express Flight 647, a McDonnell Douglas MD-10-10, veers off the runway upon landing after a landing gear collapse and catches fire at Memphis International Airport; two crew members and five passengers escape with only minor injuries
https://www.wikiwand.com/en/List_of_accidents_and_incidents_involving_commercial_aircraft
Offline james_s
« Reply #26 on: July 28, 2019, 10:12:28 pm »
Statistically speaking, heating appliances, especially space heaters are the most dangerous electrical devices in the home from a fire perspective. Both directly and also in fires caused by the relatively large load causing poor connections and low quality extension cords and wiring to heat up.
Offline Gyro
« Reply #27 on: July 29, 2019, 12:57:02 pm »
John Ward's YouTube channel is quite instructive on the danger of poor quality extension cords, power leads, cables, switches etc.
https://www.youtube.com/user/jjward/videos
Best Regards, Chris
Offline tooki
« Reply #28 on: July 29, 2019, 11:42:24 pm »
https://www.worldofbuzz.com/power-bank-plane-unexpectedly-catches-fire-passengers-forced-evacuate/
He was not-so-subtly telling you that in English, we call cells and batteries that can be recharged “rechargeable batteries”, and not “accumulators”. (The latter word fell out of common usage in English long ago, and the typical native speaker will have no clue what is meant by it.)
The following users thanked this post: Gyro
Offline Illusionist
  • Why is the rum gone?
« Reply #29 on: July 30, 2019, 01:35:22 am »
Exactly what happened to one of mine, and not a cheap one. a 2kW oil-filled radiator in our outbuilding stopped working one Winter. It looked like the fuse (I think, or maybe the contacts to the fuse) in the plug had overheated to the point that it burned out the entire inside of the plug. Even the wall socket got scorched and cracked down the middle. It had been in continual use several winters, running months at a time on full, but still a bad and potentially serious failure.
Another failure I saw was from a mains socket where just a TV was plugged in, and had been for years in my parents house. That just started smoking one day when we were sat there. The cause: a sharply bent solid wire behind the plug. It must have been ever so slightly fractured at the bend, causing a slow heat build up at that spot, causing more damage from expansion... until it finally got thin enough to heat up from the TV load and melt the insulation.
The worst one happened just a few weeks ago in our current house, again thanks to someone else's dodgy wiring: I was on the way to bed one evening and as I walked past the hallway cupboard where the (really ancient) consumer unit is, I smelled 'hot electrics', just slightly. I could feel the heat when I opened the cupboard and the metal CU was hot to the touch. Inside, the moron who had wired it had shoved two wires together into one terminal, instead of using the empty one next to it. I guess they didn't make good contact and one had gradually overheated and burned away the insulation for 6 inches down the live wire and damaged other wires near it. It probably wasn't far off being a fire.
Agilent 34410A, GW Instek 8251A, Thurlby 1905A, Siglent DS1104X-E(unlocked), SDG1032X(unlocked), Micsig DP10013 MX, LeCroy PP008 500MHz Probes, Fluke 179
Offline Bud
« Reply #30 on: July 31, 2019, 03:00:39 am »
Multi layer ceramic caps can be dangerous with a grunty PSU behind it.
There you go:
799095-0
