Author Topic: What’s this symbol?  (Read 3798 times)
Offline @rtTopic starter
What’s this symbol?
« on: March 13, 2017, 08:37:27 am »
And what’s it for in series with a superconducting resistor?
This is close to the supply input before the DP power switch where the device has a +5/+12V external supply.
It might make sense to me if perhaps the 0 Ohm resistors were supposed to be fuses and the manufacturer cheaped out,
and the unknown component is something variable with current.
Cheers :)
Re: What’s this symbol?
« Reply #1 on: March 13, 2017, 08:40:40 am »
Ok, it’s a thermistor. Still the question remains. What’s it good for in parallel with a superconducting resistor.
« Last Edit: March 14, 2017, 05:44:54 am by @rt »
Online TimFox
« Reply #2 on: March 13, 2017, 03:53:01 pm »
"NTC" means negative temperature co-efficient.  The resistance decreases as the part warms up.
If there is a pair of pads for a zero-ohm resistor in parallel with the part, that probably means that the designer gives the option to stuff one or the other part, but they have different pads.  The usual joke is that the second part is 0 ohms, +/- 5%, rather than it superconduct.
Offline james_s
« Reply #3 on: March 13, 2017, 05:10:16 pm »
I'd love to find some 0 Ohm resistors that were near the -5% end of that tolerance.
The following users thanked this post: tooki, Domagoj T
« Reply #4 on: March 13, 2017, 05:15:41 pm »
Could be they have an option to use one of a few different size NTC devices, or a polyfuse in some size, and in some applications they simply just rely on supply impedance to limit current into the circuit during start up transients.
« Reply #5 on: March 14, 2017, 12:22:17 am »
Thanks guys :)
Well in the product they omitted the thermistor,
and used the link resistor.
The thermistor footprint looks like a good place to mount fuses.
Offline sokoloff
« Reply #6 on: March 14, 2017, 12:46:04 am »
That would still be 0 ohms, though...
Offline Richard Crowley
  • KJ7YLK
« Reply #7 on: March 14, 2017, 12:52:02 am »
The following users thanked this post: Richard Head, tooki
Offline technogeeky
  • Older New "New Player" Player Playa'
« Reply #8 on: March 14, 2017, 03:21:23 am »
I still don't understand if "0 ohm" and superconducting are being used here as a joke or not. I also seem to think that the word series and parallel were mixed up in the original post. But in any case:
Thermistors are often used as quench protection triggers in superconducting power circuits. In this application (it's used all over the place at the LHC at CERN and presumably other places with intentionally- and accidentally-quenching circuits), it's used to provide a more sensitive readout for quench protection hardware. This arrangement allows for just enough of a faster readout for voltage monitoring equipment to react to an oncoming superconducting magnet quench. If you are monitoring the superconductor's resistance directly (or the voltage drop across it), it's basically impossible to react fast enough to stop an impending quench. But if you use an NTC device and monitor its resistance/voltage drop, you will get a warning signal readout just fast enough to intentionally force the quench on the superconducting link in question (and usually some nearby links, to cut off the quench from cascading).
If this is all a joke, then I'm with Richard.
Offline Brumby
« Reply #9 on: March 14, 2017, 05:01:33 am »
They would have to be superconducting to be within tolerance.
« Reply #10 on: March 14, 2017, 05:44:30 am »
I mixed up series with parallel in the second post.
Offline james_s
« Reply #11 on: March 14, 2017, 06:42:33 am »
If they were less than zero Ohms they would be producing energy rather than dissipating it.
Offline tooki
« Reply #12 on: March 14, 2017, 10:35:41 am »
Reminds me that I need to calibrate my Keithley 2015, which shows -2.5 mOhm in 4W ohms mode when shorted...
