Good evening,
Fresh blood here!
I am busy revising for a 2nd year exam in Analogue electronics and I have hit a bit of a wall.
The question is simple enough:
Question 12
An instrument is needed to monitor the temperature of a swimming pool and should give a zero reading at 28°C; the desired poll temperature. The pool temperature is allowed to swing by one degree above and below this, where the instrument should give +/-1V respectively, which triggers on and off the heating system.
Assuming a 12V supply and a bridge ratio of one determine the values of R2. And the gain needed to achieve this.
Correct Answer:
R2 = 110.73Ohms
Gain=10.0
Response Feedback:
Yes you have correctly balance the bridge at 28°C and designed the gain to trigger the system
The resistor R2 is found using the characteristic equation for the PRT in question:
100*(1+((3.85e-003)*u)-((5.87e-007)*(u^2)))
Which gives 110.7304 as required.
Using the standard Wheatstone bridge equations, Vout is 0.0103v when the sensor reads 29c - To give the +-1v swing required the gain is therefore 100. Which is not the right answer!
Any ideas where I am going wrong?
I have even modelled this question in Simulink and came out with the same gain value of 100.
Can anyone put me out of my misery?
