Author Topic: Creating a high voltage current source controlled by microcontroller  (Read 10186 times)
Offline Zero999
  • 0999
Re: Creating a high voltage current source controlled by microcontroller
« Reply #25 on: August 22, 2017, 10:38:39 pm »
Does the actual current need to be controlled by the MCU or will just on/off action do?
Well On/Off is fine in the worst case, but now that we are going to this much trouble, why not a true VCCS? is there too much difference between having it as On/Off or a true VCCS?
Because there are simpler ways of doing this if it only needs to be on or off?
Offline sean87Topic starter
  • EE WannaBee
    • EMBEDONIX
« Reply #26 on: August 22, 2017, 11:03:45 pm »
 Ok i am all ears for only an on/off solution...
EMBEDONIX - Embedded Systems, Linux and good stuff!
Offline Zero999
  • 0999
« Reply #27 on: August 23, 2017, 06:02:19 pm »
I'd use the TL431. Q1 and Q2 can be replaced with a single TIP121, to reduce complexity.
