I would like to get one of these to get some approximate values. Seems to be capable of measuring V/A like the USB power meters too, could be useful.
The unit is not expensive, but the load could be. They seem to give some 7.5 ohm resistors. Product rating comments mention that they can get very hot, but this surely depends on the power going through.
E.g. at the low end: 1.5V / 7.5Ohm = 0.2A * 1.5V = 0.3W
When testing batteries, the voltage will drop eventually. That means the current drawn by the resistor will decrease. Resistor temperature will also affect resistance and current slightly. Do I need a constant current load to measure the Ah value of a battery with this unit, and if so, is there a cheap (being the most important part) way to obtain or improvise one? Slow discharge is fine if needs be. It does not need to be adjustable.
