Most interesting point when it comes to 'tronics!
I was really busy being self employed for a long time. Now that I'm retired, I've been dusting off old project ideas, and the results are:
1. Bin time - completely obsolete approach, either
a. Better and cheaper ways available (so many mind-blowing ICs available these days!), or
b. Needed parts no longer available (curse the demons that drove the MAX038 out of existence!!!!!
2. Bin time - no longer needed for anything (NiCad battery charger - hah!)
3. Bin time - meant to be an educational exercise, and now I understand the problem too well to bother
cutting, drilling, soldering, etc.
4. Might do - if I can finish it in time to get some use out of it before it becomes needless.
5. Might do - if I can finish before the parts I need for my approach are off the market for good.
And finally ... drum roll ...
6. Doing!
Right now, I'm making a solenoid with the ability to deliver a force of several pounds - possibly up to about 8, over a working distance of a few thousandths of an inch, at frequencies of up to 5 kHz or so. This has been a massive learning exercise in magnetics, and since I don't have a machine shop, I am developing a suite of tools (including a homemade surface plate) for doing fairly precise metal working by hand, mostly to make solenoid cores out of salvaged transformers.
The mechanical stuff--solenoid and semi-precision tools- is all being done identically to the way I would have done it 50 years ago, but the solenoid drive circuitry is certainly different than it would have been just 20 years ago - I can get a used class D audio amp with 300 W/channel for only US$40, and only need to design and build the driver circuitry. Cool!!
