Good morning, so I'm hunting some microSata and mSata connectors, but I can't really find what I need.
Basically I need a male(or is it female) Slimline SATA that will connect to a laptop motherboard and then an mSata connector that will be used for an SSD, why an mSata SSD, because I want the space to keep my extra fan in the bay space as well still having an SSD and keeping the 7200rpm spinning hdd for storage.
The micro sata connector that I'm looking for is the one inside the red rectangle:
The other connector is the mSata, like this one from Molex, but one that is not obsolete:
http://www.molex.com/molex/products/datasheet.jsp?part=active/0679109000_EDGE_CARD_CONNECTO.xmlThe substitute they suggest is a bit thicker, but lacking options it will work.
Best regards.
