Author Topic: Where does the pad under the IC go?  (Read 1807 times)
Offline browntTopic starter
« on: March 03, 2019, 11:06:44 am »
I am looking at a MAX4910 audio switch
https://www.maximintegrated.com/en/products/analog/analog-switches-multiplexers/MAX4910.html
There is a copper pad underneath it. Should that be soldered to ground or somewhere else?
Offline Twoflower
Re: Where does the pad under the IC go?
« Reply #1 on: March 03, 2019, 11:19:44 am »
Unfortunately they haven't denoted the pad in the drawings. But it is highly possible that this is the EP (exposed pad) which should be connected to gnd.
Edit: Yes it is. In the drawing you can see that the Exposed Pad uses the dimensions D2 and E2 which is in the drawing the pad under the device.
« Last Edit: March 03, 2019, 11:29:09 am by Twoflower »
The following users thanked this post: brownt
Online wraper
  • Country: lv
« Reply #2 on: March 03, 2019, 11:27:38 am »
Did you actually open the datasheet?
Page 7:
EP Exposed Pad. Connect to Ground
