It's a fine assortment if you don't have any components at all. But if you already have a resistor set and some small signal transistors, diodes, etc. it's kinda expensive for what you get.
The op-amps are fine for learning, but they are old technology. Modern op-amps are much better in almost all aspects - power consumption, rail-to-rail output, offset current, etc.
