Author Topic: Where to find PoE (RJ45) Module or schematic to build one  (Read 256 times)
Offline Signal32
« on: April 12, 2021, 02:26:04 pm »
Hello,
I'm interested in getting power via Ethernet cable. There is a standard that supports this: https://en.wikipedia.org/wiki/Power_over_Ethernet
However power is not sent via ethernet by default, a module needs to communicate with the PoE switch and request power.
My question: Are there such ready-build modules that just do the communication with the switch and request power to be sent ? Or can I find a schematic for one ?
I found this on eBay but it also has a 12v transformer built which makes it much larger than necessary and which I don't need. Anyone know of a bear-bones module that outputs 48v or a schematic for one ?
Thanks!
Offline bingo600
Offline Signal32
Re: Where to find PoE (RJ45) Module or schematic to build one
« Reply #2 on: April 12, 2021, 04:03:42 pm »
@bingo600, yes, that's what I was looking for, though the module is kind of large probably due to having to deliver 15W. How can I find a schematic for this - I only need ~3W and would rather build a smaller one myself.
Offline kripton2035
« Reply #3 on: April 12, 2021, 04:04:47 pm »
see attached pdf
Offline Syntax Error
« Reply #4 on: April 12, 2021, 04:06:43 pm »
I've used these TPLink injector/splitter combinations without issue. The injector sends 48 volts and the splitter outputs at 12/9/5 volts, suitable for IP cameras, phones, etc.  They are available as seperates.
https://www.tp-link.com/uk/business-networking/accessory/tl-poe200/
Otherwise, a used managed PoE switch can be found on ebay for around $20. Just be sure it still has it's PoE rated power brick.
Offline Signal32
« Reply #5 on: April 12, 2021, 07:36:07 pm »
Thanks, the LAN8710A from @kripton2035 schematic was what I was looking for.
Offline westfw
