Author Topic: Where to get a few very basic gear for Electronic workspace -Canada/Internationa  (Read 2390 times)
Offline RHA_33
Though I'm just starting to get electronic equipment for home use, I have spent a fair bit of time looking up places to get 2' x 4' rubber ESD Mats, Static Shielding Bags (reclosable/bubble bags), and a simple ESD safe PCB sweeper tool, but I am finding it hard to find these items in Canada.
So I am hoping for some help in finding good places [in Canada or online, that ship to Canada] to purchase 'Brand Name' versions of these items.
Here is what I have found in Canada:
 1) 2' x 4' Rubber ESD Mat:
    - http://www.mroelectronics.com/mro/product.php?id_product=98 but not sure if it has an AC ground connection.  Plus it is very expensive, but a specs. datasheet is provided.
    - http://www.uline.ca/BL_7403/Anti-Static-Table-Mats?keywords=esd%20mat but they give no specs.
    - http://www.rpelectronics.com/esd-mat-antistatic-mat-60x120cm-black.html  but no specs given and doesn't look to have an AC ground connection.
 2) Static Shielding Reclosable Bubble Bags (to keep my various PCB boards / PC cards safe for reuse):
    - http://www.uline.ca/BL_53/Static-Shielding-Bubble-Bags  but they are only single use bags and provide no variety pack, so you have to purchase multiple packs, of 100 units each, to get the various sizes you need, at ~$100 per pack.  So too expensive.
    - no other source found in Canada or online for international shipping
 3) ESD safe sweeping tools (to clean off debris on esd mats and PCBs):
     - http://www.all-spec.com/products/610-108.html  - can any horse-hair brush be used as an ESD safe brush?  This links says the brush needs to be 'saturated in liquid' to be ESD safe, though they don't mention what liquid.  Don't think water would be the best.
Thanks,
Rob.
Project:
 Fix 6 yr old Asus 4870HD graphics card's spatial periodic video corruption, temporally constant.
Offline ade
Online rdl
ESD control is a good idea, but you don't need to go overboard. Check at computer places like Newegg, there you can find static dissipative mats for working on PCs. They won't be super durable soldering iron proof, but they'll do the job for $20 US or so. A grounded tip soldering iron is needed also. Generally parts will be shipped in antistatic packaging if they need it, just store them in the bags they come in until needed.
Offline pmbrunelle
  • lost mech. guy
What city do you live in?
There is Accessotronik in Montreal which has a lot of stuff:
http://www.accessotronik.com/
Don't worry about ESD so much... you're not doing production.
Offline RHA_33
Thanks for the feedback.
I'll check out the links provided.
I worry about ESD because I have fried a few computer components before by handling them, and because I want to lay my old graphics card down on a surface to visually inspect it for shorts, blown caps, etc, without worring about doing more damage to it.
I'll post what I end up buying, and where.
Cheers.
Project:
Offline PoV
  • Are you stalking me? You should. I would stalk me.
I grabbed a cheap matt off AliExpress for around $12 USD. Chinese New Year just ended, so I might actually see it next month. ;)
Offline Adam60
If you live in Ontario, check out a place called Sayal. They have several locations and carry a ton of stuff. Use Digikey or Newark Element 14. They can ship overnight for very cheap rates.
Offline nanofrog
There's a vendor on eBay based out of Canada that specializes in 2 & 3 layer ESD mats, bags, and other such products (canvu0_0). The mat material he sells is from Scientific Americas, and according to a PM I received, is made in Canada. He offers all kinds of sizes (will also do custom sizes if you PM him), different colors, and even different surface finishes (smooth & textured).
FWIW, I bought a 2 layer mat from him a few years ago, and it's been an excellent performer.  :-+ I'd buy from him again at regular street prices, as he's cheaper than any place else I've seen (only time I managed a better deal on a mat, was on a clearance item from All-Spec).
As per what you need for ESD safety, a mat and wrist strap will do, so there's no need to go nutz.  ;D
