Author Topic: Where to learn to make wiring diagrams  (Read 4215 times)
Online MuffinsTopic starter
« on: October 28, 2021, 07:36:09 am »
Hi guys.
I'm designing a machine for moving product around in an industrial environment. I have built a prototype and now it is time to formalize the design a bit by making wiring diagrams and such.
Now the difficulty I'm experiencing is that I can't find concise information on how this should be done (aren't there supposed to be standards?). I have the wiring diagrams for the other machines in the factory and they are not really similar to anything I can find online.
This is the first time I am doing this, do you guys have any tips or resources to help me figure it out?
Offline rstofer
Re: Where to learn to make wiring diagrams
« Reply #1 on: October 28, 2021, 02:37:24 pm »
Google for "How to draw wiring diagrams"  It returns primarily software solutions like:
https://www.smartdraw.com/circuit-diagram/how-to-draw-electrical-diagrams.htm
Wander the site, there's a lot of good information.
Wiring diagrams often give some sense of location.  Things that are close together in the world are often drawn close together on the diagram.  This makes the wiring diagram both easy and difficult to use.  A lot of people like wiring diagrams, I'm not one of them.  I don't like having to trace a signal all over the page.  Nevertheless, this is a very common presentation.
Ladder diagrams are more oriented toward the logic of operation with little to no sense of physical layout.  I find this more useful for troubleshooting but that's just me.
Here are some standard symbols:
https://www.nrc.gov/docs/ML1025/ML102530301.pdf
And another published standard:
https://lhc-proj-qawg.web.cern.ch/CD-ROM/Quality/QA403.pdf
« Last Edit: October 29, 2021, 03:52:11 pm by rstofer »
Offline wizard69
« Reply #2 on: October 29, 2021, 02:51:20 am »
For industrial work in the USA, ladder diagrams are the "standard".   I suggest googling "how to draw ladder diagrams".
Now there are many conventions around the world for automation drawings but I really prefer the practice in the USA.   In my opinion the approach used in Europe is crap, even more so the wire number scheme makes maintenance a nightmare.
Offline perieanuo
« Reply #3 on: October 29, 2021, 03:23:46 pm »
I use draw.io, Qelectrotech, Edrawmax for some simple drawings. Qelectrotech is open source and offline, a nice one. draw.io is online, suits diagrams for schematics like you need.
Ladder is apparently not for your job, for me is kinda plc stuff. or not?
anyway, for sketching electrical diags, those are fine
Offline Picuino
    • Picuino website
« Reply #4 on: October 31, 2021, 09:35:37 am »
« Last Edit: October 31, 2021, 09:39:16 am by Picuino »
Offline elekorsi
  • Country: si
« Reply #5 on: October 31, 2021, 01:09:42 pm »
What mathers is who and how made the diagrams. You can get shitty diagrams in both standards. I can say that i have no problems with good American (or Japanese) ones. It's only a way of presentation, if they are properly drawn, both are similar, you just have to switch it in your head. Numbering (components, wires, terminals, cables, etc.) scheme is more up to the constructor itself then the US vs EU style...
Of course I make only IEC based diagrams as i am in europe, i don't even have a software license for the NEC ones... You would be surprised how quickly you can navigate through the IEC ones if they are made properly...
I use SEE electrical from Ige-xao, as it was the most economical option when i started, it's great for what i need. I worked with WSCAD when i was employed, but this is a different price range...
For someone who needs software for really small projects, i would recommend DesignSpark Electrical, it's free for up to 15 pages.
Offline perieanuo
« Reply #6 on: November 01, 2021, 11:20:28 am »
fair enough, you can do marvels in paint or paint.net and shit in professional CAD sw
Offline Just_another_Dave
« Reply #7 on: November 01, 2021, 11:26:38 am »
I only know privative software:
https://www.eplan-software.com/
https://www.ige-xao.com/en/shop/see-electrical/
Edit: The Best 7 Free and Open Source Electrical Design Software
https://www.goodfirms.co/blog/best-free-open-source-electrical-design-software
Qelectrotech is open source and includes IEC symbols:
https://qelectrotech.org/
I’ve never used it, but it was covered in hackaday
Edit: the autocorrector had changed the name of the program
« Last Edit: November 01, 2021, 05:32:28 pm by Just_another_Dave »
Offline Vtile
  • Ingineer
« Reply #8 on: November 01, 2021, 03:17:50 pm »
There is this ZCAD open source. It have been in development past 9 years? Unfortunately I'm not informed if it has electrical symbols library.
« Reply #9 on: November 01, 2021, 05:34:37 pm »
QCAD is also open source and comes with a set of symbols for most use cases
Offline Vtile
  • Ingineer
« Reply #10 on: November 02, 2021, 10:18:28 pm »
Yeah it seems there is now much more to chose from. ZCAD is basically distributed as binaries only, so one need to compile it, so needs some skills on that, although written with object pascal so the compiling is pretty straightforward and fast. Multiplatform, comes with ZCADelectro it seems.
However, I think there is already better (is relative expression) alternatives suggested in here.
Here seems to be some precompiled versions. "Intallation" is easy unzip and run zcad.exe. It seems the 2nd latest was stable release, while latest had some missing properties.  :-//
https://github.com/zamtmn/zcad/releases
« Last Edit: November 02, 2021, 11:01:43 pm by Vtile »
Offline Terry Bites
« Reply #11 on: November 03, 2021, 04:23:04 pm »
Yes, lets lets dare say it... MS Viso!!
The following users thanked this post: Vtile
Offline Vtile
  • Ingineer
« Reply #12 on: November 03, 2021, 06:28:50 pm »
I must say after one day of use that this is really good for industrial type of electrical wirings and also some other work. I like that there is also control logic symbols attached, ie. flow charts & grafset, plus pneumatic/hydraulic symbols etc. PI-diagram library is missing, but a day of work one have own. Wery impressed of it, also the component library is nicely done (files, not database) and component editor is rather easy to use. Still figuring out how to make relations etc. advanced features mainly as wire numbering and coils and contacts etc. It shows that main developers are industrial technicians/engineers and not paid programmers. :-+
Edit. This = qElectroTech ... (as free program)
« Last Edit: November 07, 2021, 06:54:25 pm by Vtile »
The following users thanked this post: Just_another_Dave
