Author Topic: where to put oscilloscope probe of switch mode power supply  (Read 3022 times)
Offline khatusTopic starter
  • Country: gl
« on: August 19, 2019, 06:53:15 pm »
Hello guys i want to measure switching frequency of a 220 to 12 volt dc switch mode power supply.But i am confuse where to put the oscilloscope probes.Can anybody tell me where i can put those probes..
Offline MosherIV
Re: where to put oscilloscope probe of switch mode power supply
« Reply #1 on: August 19, 2019, 07:13:12 pm »
If you do not know - DO NOT DO IT !!!
These types of smps are incredibly dangerous!
They work by first rectifying the mains voltage to give you 240V DC , with all the energy of live main as well !
Then this is switched/pulsed into the small transformer at high (50KHz or higher) frequency.
The secondary side is rectified into a capacitor.
This voltage is measured and the difference from the setpoint voltage is fed back to adjust the  frequency of the pulses.
The freq or pulse width is adjusted to keep the output voltage (or current for constant current psu) at the correct value.
Online tunk
  • Country: no
« Reply #2 on: August 19, 2019, 07:25:41 pm »
Connect them to the 12V output - the filtering isn't perfect so it should give you some idea of the frequency.
Offline PA0PBZ
« Reply #3 on: August 19, 2019, 07:30:11 pm »
Otherwise the anode of D7 should show you what you want, with the ground clip of the probe connected to the negative of the output. But beware, if you don't know what you are doing it can kill you, your scope and your cat!  :scared:
Offline Canis Dirus Leidy
  • Country: ru
« Reply #4 on: August 19, 2019, 09:15:40 pm »
For some practical purpose or just out of curiosity? In the first case, just look at the datasheet - the switching frequency of VIPer22A is fixed (60 kHz).
P.S. But in any case, poking into the power supply with the oscilloscope (unless PSU is connected to mains through isolation transformer) is a really bad idea.
Offline tggzzz
« Reply #5 on: August 19, 2019, 09:28:41 pm »
To measure the frequency you probably don't have to connect the probes to the SMPS. EMI should give you a regular "disturbance" at the switching frequency.
If you really need to connect a probe, an HV differential probe is the right type of probe to use.
Online Zero999
  • 0999
« Reply #6 on: August 19, 2019, 09:43:43 pm »
You can probably just connect the probes to the output and use the AC coupled setting to monitor the ripple which should correlate well enough to the switching frequency.
Never mind that, those switched mode power supplies don't appear to be very safe or comply with the EMC standards. There's no Y capacitor and there appears to be insufficient creepage distances, but it's impossible to know, without seeing the other side of the board. Please post some pictures of the other side of the PCB.
  • Country: gl
« Reply #7 on: August 20, 2019, 08:23:18 pm »
Here is the picture of back side
Offline perdrix
« Reply #8 on: August 24, 2019, 05:36:54 am »
Arggh! Not a single anti-creepage slot and clearances look way too low for 230V AC.  Where did that dangerous rubbish come from?
