I am interested in calibrating equipment on my own, and I would like to start off by calibrating my own equipment. (I am not talking about becoming accredited/licensed to calibrate other people's equipment, I understand that I would probably need to start off with some NIST traceable calibrated equipment if I wanted to do that.) However, if I were to purchase a used piece of equipment, I would like to be able to do some work on said piece of equipment and be able to say with a certain degree of confidence that it is now calibrated.
Here is a list of my current equipment which was all purchased second hand.
HP 4192A impedance analyzer with 16047A test fixture
HP 8753B VNA with opt 10 and 85047A S Parameter test set
85032B type N calibration kit
HP 3403C RMS voltmeter
Tek 2465B 400 MHz scope
Tek 2232 100 MHz scope
Various probes / test leads / adapters / connectors
Fluke 81 function generator with pulse generator capabilities
Cheap multimeter but I will be picking up a couple of good ones soon
Will also be picking up a couple of variable power supplies soon
If you were me, where would you start? Is there a certain machine that I should calibrate first since its accuracy is more important than the rest? Or will I need to have at least one specific machine professionally calibrated to give me a starting point that I can trust, and if so which machine?
Thanks
Mike
