So,
One of my ceramic infrared heating elements came broken. I believe it was broken during shipping. It's not a quick fix, it will take a good amount of time. I was curious though, if I'm going to spend a lot of time getting to the broken one, maybe instead of putting the cheaper ceramic heating elements in there, I should go for nicer ones, like Elstein's.
I was looking at a few of the Elstein products and I like the Elstein SHTS Series. My current unit has two 150 watt / 230V and it's supposed to have four 600 watt / 230V heating elements. The Elstein SHTS Series has the 600 watt heating elements but the lowest they go is 300 watt. Could I just upgrade the two 150 watt units with two 300 watt Elsteins or would more need to be done, like the circuit itself might need to be adjusted?
I thought I'd just purchase four 600 watt / 230V SHTS Series Elstein's and two 300 watt / 230V SHTS Series Elstein's. The other option would be to purchase the HTS Series I guess. They make a 150 watt and a 600 watt (around the right sizes as well).
The measurements for my current heating elements are roughly:
240mm x 61mm (600 watt)
65mm x 73mm (150 watt)
The Elstein's seem to come in the following measurements:
SHTS SERIES (the ones I really like)
125mm x 125mm (1200 watt) SHTS
250mm x 62.5mm (1200 watt) SHTS/1
125mm x 62.5mm ( 600 watt) SHTS/2
62.5mm x 62.5mm ( 300 watt) SHTS/4
HTS SERIES
125mm x 125mm (250, 400, 600, 800, 1000 watt) HTS
250mm x 62.5mm (250, 400, 600, 800, 1000 watt) HTS/1
40mm x 62.5mm ( 125, 200, 300, 400, 500 watt) HTS/2
62.5mm x 62.5mm ( 60, 100, 150, 200, 250 watt) HTS/4
I believe there's enough room for the 250mm x 62.5mm HTS/1. When I was posting these, I just noticed the SHTS/1 is 1200 watt. I don't think I want to replace all four 600 watt units with the 1200 Elstein ones. And I think if I went for the much smaller size, 125 x 62.5 SHTS/2, it just wouldn't work. What do you guys think?
I can also order, what I believe is the exact same replacement for 11$. I just thought so long as I have it opened, might as well upgrade it with something a little nicer. From what I've read, low quality IR heating elements have wrecked havoc and are generally discouraged against.
Here's a link to the ones I currently have I believe (the 600 watt ones):
http://www.aliexpress.com/item/Free-shipping-Bottom-ceramic-heating-plate-600W-220V-240-60mm-for-BGA-rework-station/32508868958.html?spm=2114.40010608.4.44.SJfZF9I guess maybe it's either the Elstein HTS series or just the original low quality ones.
