1) Are you planning to use through hole or surface mount?
All through hole components.
Anyway, best to present as much detail as you have about the design.
Sure. Apart from posting the PDF with the schematics I don't have much to add (mostly due to ignorance on my part).
A lot of the vocoder is already done such as the main ("analysis/synthesis" or "filter") board. I used the components listed in the DIY article for that.
Then there's a bunch of smaller boards that are halfway done (LED PPM meter boards, input amp boards, slew rate board, output amp board, internal excitation board), and I'm missing some components for those, including capacitors of various types.
So, as I understand it from the replies here: there's no "one type for all" even in this design.
I'm looking at Farnell's website as I'm creating an order there, and I don't see any entries for either polyester nor polycarbonate capacitors, and I understand why, from Ian.M's reply stating that they are no longer produced.
Generally, modern low ESR aluminium 'wet' electrolytic capacitors have comparable performance characteristics to tantalums at a far lower price point, but greatly inferior life to a properly derated tantalum capacitor.
You mean a tantalum that has say a 50V rating and used for circuitry using only 12V will likely perform much better (and have lower risk of failing) than say one that is rated at 16V in the same circuit?
However aluminium solid polymer electrolytics are nowadays readily available and have superior characteristics to tantalums, comparable life, and aren't little incendiary bombs waiting to trigger, don't contain conflict minerals, and are at a comparable or lower price point.
Are those spceialized electrolytic capacitors? Should I look for "solid polymer aluminium electrolytic capacitor", or are you referring to commonly available modern electrolytic capacitors in general?
A bigger issue is the change in commonly available film capacitor dielectrics. The favoured high quality low loss dielectric back in the '80s was polycarbonate, and for low leakage, polystyrene but the last factories manufacturing capacitor grade polycarbonate and polystyrene films closed circa Y2K, so both types of film capacitor are only available as $expen$ive$ N.O.S. of dubious quality due to possible degradation in improper storage.
No wonder I couldn't find any at Farnell.
Should I look for "film capacitors" wherever the DIY article states any of these?
As the ETI design is full of complex analog filters, capacitor stability and precision are the main factors that will drive your choice of replacements for the original polycarbonate film capacitors.
True. The more precise values/stability I can get the better the audio results.
I'm aiming for a good as possible result within a reasonable cost of course. I'm guessing this also means that I should order the components I'm missing (mostly resistors and capacitors now) from reputable dealers (Farnell, Mouser, Digikey etc.) and stay away from low cost sites such as Tayda etc. even though there's probably a considerable saving involved.
