Hey guys, I did a quick google search for ways to convert DC to AC as I have a bunch of different unidentifiable transformers that I would love to be able to use.
The results usually gave me either how to make a spot welder, or use a car battery to power household appliances. Neither of which is anything near the results I wanted.
I can see from a majority of diagrams that most people use a 555 timer, to make the oscillations.
However, I don't have any IC-Chips that could do that.
But I do have some transistors, mosfets, etc.
I also have an Arduino which could be implemented if that would make things easier.
So what I'm basically asking for, is help in creating a simple low-voltage transformer tester.
The testing voltage doesn't have to be high, as i just need to see the conversion ratio on the transformers.
Is there a simple method that I'm just missing all together, or is there a way to make this happen without having to purchase extra components?
Also, I've tried figuring out what would happen if I simply connected a transformer without any load, to my mains (230v) but I couldn't really figure out the answer from google (may just be my search terms that weren't the ones I should have used.), so in fear of blowing my fuses, I haven't done it.
Thanks in advance for any and all help
