I’m currently on the hunt for a mini FPV drone, and I’ve been considering two great options: the new Meteor75 Pro with the O4 system and the Air75. However, I’m a bit undecided, as I want to use the drone for indoor freestyle flying. Both drones have their own strengths, but I’m having trouble choosing the right one for my needs.
The Meteor75 Pro caught my attention because it comes with the O4 system, which promises improved image transmission quality and range. The O4 system is known for its low latency and solid connection, which is definitely an advantage if you're flying in more challenging environments or need crisp video feed during tricks. However, I’m wondering if this system is too advanced for indoor flying, where range isn’t as much of a concern. Will the Meteor75 Pro be too powerful or overkill for the tight spaces I’ll be flying in?
On the other hand, the Air75 is a bit smaller and lighter, which seems like it could be a better choice for indoor flying. Its compact design could be perfect for navigating tight spaces and performing freestyle maneuvers within the house. The smaller size also means it could potentially be easier to handle in a confined area, reducing the risk of crashing into furniture or walls. And I think that it will come with O4 unit too, so I dont know what to do.
What do you recommend?
