Hello All,
I am glad to have found this EEVBlog Community - the information and references have been outstanding - I recently selected the Siglent SDS1104X-E as my scope. I have been testing various functions to get better acquainted with the capability of this Scope.
I have enabled, via hack codes, the WiFi (which is operational) and the AWG and MSO functions (although not used).
I am focused right now on the Decoding capabilities. Have successful tested the I2C decode.
As I have moved on to the SPI and have had no success with the decode. Closely followed the setup instructions from the User Manual and still have had no success.
My setup is having two Arduino UNO boards successfully communicating with each other -
Here is a screen shot of the signals (hopefully this attaches)
I have no idea why the decode is not functioning -
Triggers are all at 1.x Volts; Have confirmed connections, CS is CS~, the signals all look good. The width between messages is 1 to 10 mS.
I have also downgraded the firmware to 6.1.25 to make sure that there was not an obvious bug in the firmware - no change - which based on the inputs from the forum, I did not expect that to be a difference.
Can anybody provide some guidance to what I am doing wrong.
Thank you,
- Attachments and other options
