It is cross-platform (Mac/Win/Linux) and based on an open sourced commercial CAD kernel (OpenCascade). OpenCascade has native support for BREP/STEP/IGES, as well as the common mesh and 2D file formats.
+1 for openscad. It's parametric, similar to common programming languages so once you defined the model you can easily tweak the dimensions. It's is also supported by thingiverse which is nice.
Here is an example of a project box designed in openscad https://github.com/zapta/arm/blob/master/phone-finder/3d/phone_finder_case.stl (https://github.com/zapta/arm/blob/master/phone-finder/3d/phone_finder_case.stl) and here is the code that generates these customizable LED standoffs http://www.thingiverse.com/thing:1710714/#files (http://www.thingiverse.com/thing:1710714/#files)
// LED PCB standoff generator.
// +0 to hide in thingiverse customizer.
eps1 = 0.01+0;
eps2 = eps1 + eps1;
// Outer diamter.
outer_diameter = 4.0;
// Total height.
height = 8.0;
// Spacing betwene the centers of the two leads.
leads_spacing = 2.54;
// The diamter of the lead holes.
leads_hole_diameter = 0.9;
// 0 for a closed hole. 1 for an open slot.
use_open_slot = 1;
// Values below 1.0 reduces the footprint of the standoff at the
// cost of reduces stability.
width_factor = 0.8;
// Number of rows to generate.
rows = 2;
// Number of columns to generate.
columns = 4;
// Spacing of printed rows and columns.
part_spacing = 5;
// Number of faces to compute per 360 degrees.
$fn=64;
// A single LED lead hole or slot. Positioned at the
// positive X direction.
module lead_hole() {
module hole(offset) {
translate([offset, 0, -eps1])
cylinder(d=leads_hole_diameter, h=height+eps2);
if (use_open_slot == 0) {
hole(leads_spacing/2);
} else {
hull() {
hole(outer_diameter);
// A round standoff, before applying width_factor.
module round_led_standoff() {
difference() {
cylinder(d=outer_diameter, h=height);
lead_hole();
mirror([1, 0, 0]) lead_hole();
// A round standoff with width_factor applied.
module led_standoff() {
dx = outer_diameter + eps2;
dy = (width_factor * outer_diameter) + eps2;
dz = height + eps2;
intersection() {
round_led_standoff();
translate([-dx/2, -dy/2, -eps1])
cube([dx, dy, dz]);
// Generate the array
pitch = outer_diameter + part_spacing;
for (i = [1:columns]) {
for (j = [1:rows]) {
translate([i*pitch, j*pitch, 0]) led_standoff();
