Author Topic: Which new Multimeter i should buy  (Read 17811 times)
Offline IrukandjiTopic starter
Re: Which new Multimeter i should buy
« Reply #25 on: February 01, 2019, 07:20:27 pm »
Can the Aneng An 8001 - 8009 or the renamed models measure 10mA or 20mA? I dont know if i understand it right on the eevblog video to the aneng 8008 but it saw like he cant measure it. But the aneng 8001-8008 is not safe to measure 230V if i only put the probe in the 230V socket?
The Uni-T UT139C looks save when i understand it right on the video from joe smith.
Offline mvs
« Reply #26 on: February 01, 2019, 10:37:57 pm »
AN8008/AN8009 DMMs can use 1A range to measure this currents. It is not the best way to go, but it is acceptable for small meters. The problems are 0.1 mA resolution and 1% +3 digits accuracy (for 10mA it is +/-0.4mA).
UT139C is larger, has better build quality, more functions (REL, MIN/MAX, NCV, ...) and current ranges. It can make 10mA and 20mA measurements using 60mA range, with 0.01mA resolution and better accuracy (0.7% +2 digits, for 10mA it is +/-0.09mA).
I would not recomend you to use any pocket meter for this job.
« Last Edit: February 01, 2019, 10:40:36 pm by mvs »
« Reply #27 on: February 02, 2019, 01:16:34 am »
I think i buy now two multimeter's. One is the Uni-t UT 139C and the other one is one of the aneng 8002,8008 or 8009 or renamed model. These 3 models and the renamed models are same accurate or?
If i buy the Uni-t UT 139C about Amzone how i can know if it a europe version? I read there is a china version of the ut 139c on the market is it true and what is different?
best regards :)
Offline rstofer
« Reply #28 on: February 02, 2019, 02:02:26 am »
If you want the CAT ratings to be real, look for the icon of an independent testing agency like UL or ETL (and whatever the German equivalent is) somewhere on the meter.  CE doesn't count because that is usually a self-certification.
The Aneng 8008 is NOT UL Listed, the Brymen BM235 is.  One can assume that the 235 actually meets the CAT ratings.  No such assumption can be made for the 8008.  For my purposes, the CAT ratings are not important.
The EEVblog 121GW meter is not UL Listed but it is listed by ETL - an independent testing agency approved in the US.  So, it's listed...
Offline Darkwing
  • Let’s get dangerous!
« Reply #29 on: February 02, 2019, 11:30:40 am »
I think the Uni-T 139C is a good choice for you. With it you have the ability to easily access the small fuse. When you buy a meter, also buy a set of fuses in the right size. You may need them one day. ;)
In case of the Uni-T 139C that is: 6x32 mm  FF 600mA H 600V (according to manual).
EDIT:  About safety and mains, here is how I see it:
Every Phasenprüfer for 1 Euro is more "unsafe" than your multimeter. When people say, "the meter is not save on mains", this does not mean that it will automatically turn into dust when you measure mains with. I read the linked article above: it basically says, that you need to be careful and that a good quality meter doesn't protect you from main, but it helps to protect you a little bit from your own stupidity. I ALWAYS treat mains with respect. I plan every hand move very slowly and don't take any risk, when I work with it. And you should too – but most of all: don't be afraid, or you shouldn't do it at all. Don't be too concerned about CAT ratings, they don't protect you from your own stupidity. Such a meter is ok, when you occasianally want to work with mains. Should some day come and you find yourself working on mains routinely on a daily basis: then by all means get a very good meter, that is suitable for this kind of job! But for now, I only can say: I measured 15A 240V with my 25 Euro Multimeter VC97; I'm still alive and so is the meter. ;)
« Last Edit: February 02, 2019, 11:52:31 am by Darkwing »
The following users thanked this post: exe
Offline mvs
« Reply #30 on: February 02, 2019, 12:32:24 pm »
8008 and 8009 have more counts, so in some cases you can get better accuracy and resolution.
I doubt that UT-139C has country specific versions like it was the case with UT-61E. Check the fuses as it arrives, they should be HRC.
Or you can buy it from pollin or reichelt to be sure.
Offline FrankE
« Reply #31 on: February 02, 2019, 07:36:35 pm »
I spent a fortune on cheap meters when I was younger. None lasted and it was a false economy. The traces lifted on every cheap one with a rotary switch. Though I've more expensive meters including a logging one and a bench one I use a Fluke 117 extensively. It's aimed at electricians and has no microAmp range.
Even if I'm not working or doing much in the way of electronics it gets used for checking fuses and batteries and other household stuff.
The following users thanked this post: Mr. Scram
Online exe
  • self-educated hobbyist
« Reply #32 on: February 02, 2019, 08:55:50 pm »
Only in some cases :). E.g., for 3.3V they will have same resolution. Only between,e.g., 6V and 10V AN8008 will show one digit more. Also AN8002 uses same (or similar) 10000 count chip, you can get more counts by changing flags.
Offline joeqsmith
« Reply #33 on: February 02, 2019, 11:35:24 pm »
.... The traces lifted on every cheap one with a rotary switch. ...
Wow, that's pretty bad and not something I have run into.   Would have liked to have seen some closeup pictures of the traces.
« Reply #34 on: February 15, 2019, 05:47:50 pm »
Hi guys,
i want to tell your that the Aneng AN 8008 and the Uni-T UT139C arrived me. Thanks so much for your help.  :-DMM :-+
https://www.bilder-upload.eu/bild-1698ed-1550252675.jpg.html
« Last Edit: February 15, 2019, 05:51:35 pm by Irukandji »
Offline alex-sh
« Reply #35 on: February 15, 2019, 07:02:12 pm »
With cheapometers in general you can not trust ANY ratings. Think of it like this: the (chinese) manufacturers themselfes don't even have a clue what they are printing on there.  ;D  They sell them to you, that's all.  ;)
When I decided for the VC97, I loved M. J. Lortons videos about it; see them here:
Review: Part 1 - Vichy VC97 vs Victor V97 Multimeter
Review: Part 2 - Vichy VC97 vs Victor V97 Multimeter
They are around 25 Euro on German ebay.
Vichy
This was my first DMM.
It was very precise until it stopped working.
For you budget, I do not think you can get a really decent meter. Maybe Uni-T or Vichy?
However, I would seriously consider Brymen (Korea). For a little more, you are getting a better quality meter, which you can trust.
