Author Topic: which parts for wiring a 4pin connector  (Read 952 times)
Offline LaserTazerPhaserTopic starter
« on: May 13, 2019, 10:54:32 am »
Does this need ferrules or something else?
https://www.digikey.com/product-detail/en/1-480703-0/A1453-ND/29345/?itemSeq=291952439
Perhaps Digikey carries the appropriate parts for this specific connector I haven't done much connectors not sure which is correct method to get this working.
Offline MarkF
Re: which parts for wiring a 4pin connector
« Reply #1 on: May 13, 2019, 01:12:05 pm »
The mating connector and associated contact pins/sockets are shown at the bottom of the Digikey page you linked to.
You will also need a crimping tool.
The following users thanked this post: LaserTazerPhaser
Offline oliver602
« Reply #2 on: May 13, 2019, 06:31:02 pm »
Here is a selection chart for the different TE Mate-N-Lok contacts and housings.
« Reply #3 on: May 13, 2019, 09:58:13 pm »
Going to obtain these https://www.digikey.com/product-detail/en/350547-1/A14300-ND/213765/?itemSeq=292610804 how do they plate the inside with 2 separate metals without plating the outside with the same metals?
Online oPossum
« Reply #4 on: May 13, 2019, 11:50:41 pm »
Probably plated before stamping.
Offline akowalczyk
« Reply #5 on: May 14, 2019, 05:49:26 am »
Helpful hint: Proprietary crimping tools can be very, very expensive. I recommend a good set of needle nose pliers to close up the crimp much like the real tool would. Do NOT solder them, as they will be unreliable and the resistance can vary/cause fires and other badness
Happy Crimping!
1. Always read the datasheet
2. Never trust the datasheet
